Rinker 370EC Forsale Low HRS
SimcoeRinker400SimcoeRinker400 Member Posts: 338 ✭✭✭
Hi Everyone,
My friend has asked me to help sell his 2007 Rinker 370 EC.  If you know anyone looking for a boat just a little smaller than my 400 or a little bigger than a  342.  It can be shipped to the US.  The boat only has 260 hrs very clean boat the bottom was redone this spring.  Here are other specs on the boat.  $125,000.00 CAD  Reason for him selling is he is getting out of boating.
NEW
Water heater 2022
Out Drives rebuilt for years of worry-free boating 2019
The bottom was redone with fresh Paint the proper way sanded down and repainted 2023.
New Starter battery 2023
Bow thruster battery 2018
Full Compound and Polish 2023 Deck and Hull
Factory New water line and deck strips installed 2023.
Specifications:
   Beam:                                                12 ft. 3 in. (3.73 m)
   Bridge clearance:                           13 ft. 0 in. (3.96 m)
   Draft [drive up]:                             24 in. (61 cm)
   Draft [max]:                                     36 in. (91 cm)
   Weight:                                             18,400 lbs. (8,255 kg)
   Length overall:                               40 ft. 5 in. (12.32 m)
Body / Hull
   Hull material:                                                  Fiberglass
Engine and Drivetrain
   Engine/s:                                          Twin Volvo 8.1 GXi DP - 375hp
   Fuel tank capacity:                        235 gal. (889.6 l)
   Fuel type:                                         Gas
   Drive type:                                       I/O - Twin
Operational Info
   Headroom:                                      6 ft. 8 in. (2.03 m)
   Sleeping capacity:                         6
   Water capacity:                              51 gal. (193.1 l)
   Holding tank capacity:                 45 gal. (170.3 l)
   Holding tank capacity - Gal:       45
Picture of us hanging out my 400 and his 370
2008 Rinker 400 EC
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
Post edited by SimcoeRinker400 on
    edited August 2023
    Wow that boat is in beautiful shape!! And most importantly… hardtop!!
  • PickleRickPickleRick Member Posts: 4,263 ✭✭✭✭✭
    edited August 2023
    I have a very large 28 footer, your cockpit sink/counter is bigger than what I have in the cabin. Definitely makes me want to upgrade. Very beautiful boat and looks like it lives up to the rinker status quo of cleanliness. That being said please post pics of the engine compartment!!!  Even us diesel fans love the 8.1.
    X2 for hard tops are the best....let the argument begin lol
  • captkevincaptkevin Member Posts: 470 ✭✭✭
    Very nice looking boat.
  • alex8q4alex8q4 Member Posts: 66 ✭✭
    Nice boat.  Can anyone talk about fuel burn specific to this setup?  My 342 gets me roughly 1mpg at 3800 rpm and 26 to 28 mph cruise.
    2006 342FV - Ontario
    This boat is the boat that got me into Hardtops.  Went for lunch on my friend's 370 from my 342 then I was like no heat from above ( I had Dark blue canvas on my 342).  After that weekend started looking and found the Rinker 400.
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    Agreed @SimcoeRinker400 - the difference between a dark bimini and a hardtop is considerable. A white bimini would be great if not impossible to keep clean.
    edited August 2023
    Whereabouts (or should that be aboots? :D ) in Canada is it located?
    2013 276 Cuddy ~ 350 MAG / B3
    JoeStang said:
    Whereabouts (or should that be aboots? :D ) in Canada is it located, eh?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,841 mod
    uh oh, is Joe considering a family mobile?? :smile:
    @JoeStang Boat is located on Lake Simcoe just north of Toronto.
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    @JoeStang
     Good price if you're converting the CAD to USD..
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
  • tricountytrailtricountytrail Member Posts: 233 ✭✭
    I have 2005 360 Fiesta Vee Same Boat With Mercruiser 496Mags and Bravo 3s
    full water and fuel
    4MPH 650 RPM 2.5GPH =1.6 MPG 8 People
    28MPH 4100 RPM 51GPH =.55 MPG 8 People
    32MPH 4200 RPM 53GPH =.60 MPG 8 People
    37MPH 4600 RPM 63GPH =.59 MPG 8 People
    Does this have the composite volvo drives?
  • LaReaLaRea Member, Moderator Posts: 7,965 mod
    @tricountytrail - you might be under-pitched.  Mine 2007 370 would do 0.8 mpg at 32 mph, and 0.7 mpg at 43 mph.
    @larea your 370 would do 43mph? wow.
    I hit 44 a few times at WOT.
    @tricountytrail I will have to ask but I don't think so.
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    edited August 2023
    @YYZRC
    I hit 47 MPH in my 400 half water and half fuel tanks Trimmed up minimum tabs out :)  GPS speed not speedo.  @Dream_Inn have you tested out your 400 for top speed??  My 342 was disappointing with the 270 Volvos only top out at 38 MPH.  400 with the 8.1's can do over 40 mph easily but it is not healthy for the drives to crank it all the time. :)   I like to cruise around 31mph anything below that it wants to fall out of plane unless full tabs are out.
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    I believe the 370 can do 50 mph with the big engines??
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    @SimcoeRinker400 I hope the broker fee is minimal. Zero effort on the listing description.
    So, before I changed out my props to the Hill Marine big cows, I hit 45-46 mph at top end.  With my big cow props (I have B-2 drives), I get 42-43mph.  But, unlike @SimcoeRinker400 , I now can stay on plane at 20mph and have good fuel burn.  She also gets on plane easily in 6 seconds (let me tell you, people are very shocked when they go for a ride and I never need to come close to full throttle coming up on plane). I cruise between 31-33mph usually averaging 0.7mpg.  Sometimes I'll see 0.8 mpg.  For anyone that is waiting for a little bit larger Rinker (390 with Diesels), I know of one coming up soon.
    @Dream_Inn
    Did you change out your Bravo 3X Drives for Bravo 2's ??  Why I ask I have been having issues with one of my Bravo 3x's
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    @YYZRC
    The Beaches Guy will not remove it from his site as my friend told him that he was going to do it privately..  He was like you can never sell it privately.  I have sold all my boats privately..  He was let's see who sells it first was his response.  Anyway, he should not have it on his site. We will see I think the market from the feeling I am getting is really slowing down!!!
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    Agreed! I think the boat market is pre-pandemic now.
    full water and fuel 8 People
    edited August 2023
    @Dream_Inn
    No, I bought it with B2s.  I was unsure until Allen W. said he prefers the larger single prop with the bigger cruisers.  Unfortunately I’ve had a total of 3 new outdrives.  Two were due to hitting something in the middle of a channel, the third was found to be a defect of a gear.  I have been very happy with performance, especially with the 4 blade SS props.  I have to say that with the original 3 blade aluminum, I had problems with the hubs failing after a year or so.
    I did a lower unit in last year starboard side than this year caught the starboard upper drive gear going that sounded like a U-joint.  One thing I did add to the boat was drive showers last year which I think help keep things much cooler than having the drives just hang out of the water while crusing. :)
    https://www.driveshowers.com/
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    Yeah, I think the family would want to get out more & often with more space and amenities. The 276 is so easy and cheap to operate, but it sits more than I like now. :(
    Thanks. Is there any relatively easy to way to get it to Huron or Erie? I'm guessing no trailer for it. I'm in Metro Detroit so shipping would be super expensive I'm guessing....
    @JoeStang
    Agreed, and really clean 40'ish boats with nice options are getting harder & harder to find near the $100k mark.
  • WillhoundWillhound Member Posts: 4,228 ✭✭✭✭✭
    JoeStang said:
    Yeah....drive it. Huron is connected to Simcoe via the Trent Severn river/canal/lock system.
    It would be a beautiful trip with family up the Trent and across Georgian Bay in the fall. Unforgettable.
