Bottom Paint Recommendations - Great Lakes
YYZRC
Member Posts: 5,508 ✭✭✭✭✭
As much as it kills me, I have to bottom paint the boat this fall. The early start to the season and the warming waters have led to insane algae growth, hindering performance.
@kordo what did you end up doing? @SimcoeRinker400 and @Liberty44140 what are you running?
I refuse to sand or media blast my hull so I need a paint that works with only a light scuffing prior to application.
Lots of compatibility charts are out there to help decide which would be best for your boat - and the ease of applying.
Probably the most popular down by us is Micron CSC. I usually get 3 (6-month) seasons after a two light coat application. I just do a light scuff with a 3M pad and apply. Works for me.
The first time needs to be carefully prepped and applied otherwise you can open up a whole can of worms - and any subsequent applications will be a waste of money. Just like painting your house the results are all in the preparation.
Here is a sample application instruction for Micron CSC first time painting of bare fiberglass:
Once you have a proper base applied that's when it's easy every year or so to recoat and stay protected for the life of the boat.
If you don't feel up to this big of a project, I would recommend you get a professional to do a proper initial prep and application - and then you can do future touch-ups yourself.
That's what I've done on both our boats. Had the pros do the hard stuff for the first time, now I just recoat as needed.
My boat was a blank canvas it had to be sanded then we put Interlux products That is my preferred bottom coat system for Lake Simcoe works great easy to clean in the fall quick power wash. So I put InterProtect 2000E then the Bottom coat. You could also do VC17 it's all preference. I think after Spring 2021 its shinier now than the older Bottom Coat I used.
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
2000e just seals the hull up and is a good primer. The no-sand method sounds good but I have been around boats since being little and I was also taught the sanding method and have never had an issue with the bottom coat coming off. That link was a good read though I would do that on a smaller boat. If it peels on our bigger boats it could be a PITA to fix.
2015 Scarab 165G
Laser Sailboat
I've not seen if these are allowed at the marinas but these are popping up all over private docks.
There's another style all the wake boarders with inboards use. Can't paint a wakeboard boat hull because that keeps the fish from hearing your crappy country bro rap played at full blast despite no one else wanting to hear it at any audible level.
