Transducer Install
2»
  • oscar1oscar1 Member Posts: 762 ✭✭✭
    I want to install an active imaging transducer on the trim tab. I know this isn’t recommended but I don’t want to drill the transom and I’m wondering if anyone has done this? I realize it won’t work on plane but I don’t need it then anyway.
    The style of transducer seems ideal for flush mounting on the tab.
    Did you ever install the transom transducer? and Merry Christmas.
  • YYZRCYYZRC Member Posts: 5,181 ✭✭✭✭✭
    edited December 2023
    Yes, I installed it on the trim tab. Worked great and was accurate for depth but it didn’t work on plane (not a problem for me). I cut the wire so I only had to drill a small hole in the transom (about 3/8”).
    I removed it because I made new trim tabs. Will reinstall in the spring, probably on the trim tab again.
