Atwood hot water heater
John41
Member Posts: 120 ✭✭
I have a 2004 342. My Atwood hot water heater is no longer making hot water. I believe it could be the heating element. The part number is 91580. I’ve tried to order the part but it’s not available. I did find one but it’s 1500 watts, my hot water heater says 1400 max. Does anyone have any knowledge on this or advice? Thanks
It's a 6-gallon heater, but you need to figure out whether your heat exchanger is on the front or the side. Mine on the 370 was front mount, model 11811. Only $320 on eBay!
https://www.ebay.com/itm/145688997340?chn=ps
Did you run out of hot water with the 6 gallon? Just curious, as we use our shower with a family of 4 and never run out of water. This goes back even to our 310 that we had back to 2006.
We actually used both showers last time since we had guest onboard.
Just sounds funny when we talk about suffering while be able to shower on our boats. 🤣.
I had to replace my shower heads because they were both Euro-style torture devices that would drill pinholes in your skin if you stood too close, and would splash water everywhere.
I need to order the two vhf antenna mounts. They are currently plastic but I want the stainless ones.
