Water system pump
rasbury
Member Posts: 9,027 ✭✭✭✭✭
Our last outing the water pump quit cycling- this past weekend I had a limited time to look at it- me and electrical...so I got to the connector at the pump and probed the hot side while jabbing the ground and not seeing power- I stretched the ground to the generator ground too-i don't see and breakers popped- start at the switch?
Our switch crapped out mid weekend last season. Perfect time to go bad when the mother in law was down with us
Makes it a little more complicated.
I'm lucky to have mine mounted in the galley behind the sink next to my cabin master light switches.
Only two of those wires are for your pump. The others are make it light up when you turn on your helmet lights.
