Fiberglass Rectangle
rooh9699
Member Posts: 10 ✭
Hi all,
I have a 2006 270 Fiesta Vee. Remodeling the front cabin. When removing the table support floor to inspect the bow area, i see a clear almost see through rectangle of fiberglass it's about 4 inches by 2 or 3 inches. It appears very solid and original. Do you have any idea what this is? Ty so much for your time and expertise. D
In your pic, you have the fridge out. I just took my galley out to rebuild it. Was in fairly good shaoe, but wife wants a differennt color.
Question: Did your fridge condensate hose just drop down through a hole where the fridge is? I assume it runs to the rear bildge?
Was thinking about adding a sump pump for that and the sink to make it cleaner.
Ty again for looking and please let me know if you need anything from my end. We have the cabin gutted.
Dave
Maybe. I reglassed it and shaped it a bit to ease flow of water from there to mid bildge. It appears very thick.
Ty for your response.
Side note: using an "extreme" carbide tipped blade on the multi-tool cut far easier and faster than a jig saw and definitely lessened the risk of chipping the gelcoat.
