1…124125127129130…145
  • Rich_Rich_ Member Posts: 351 ✭✭✭
    Sent the kids out on their own for a ride
    With a little help from my son - who did the crawling and laying under the hull - finished polishing the hull and bottom paint touch-ups. Splash is scheduled for next week.
  • aero3113aero3113 Member Posts: 9,929 ✭✭✭✭✭
    I’m scheduled for the 15th! ⚓️
    edited May 2025
    Launched the boat today. River was all good then when we went through the lock to the lake we were hit with a heavy fog. Visibility was about 50 yards. Took about an hour and all my local knowledge (i.e., instinct) and electronics to go the four miles from the lock to our dock. I think I'd rather be in heavy seas instead of fog.
    Had a little fun test run with her ⚓️
  • YYZRCYYZRC Member Posts: 5,487 ✭✭✭✭✭
    Not ideal.
    edited May 2025
    D@mn, I had that happen to my 242 years ago.
    Ouch! Is that your shore power? How did you know to check it?  And glad you did!
    It was my shore power AC inlet. We were running the heat last night and it just cut out around 5am. Really glad it didn’t cause a fire!!
    Lucky I have 2 like new inlets from when I removed them from the starboard side.
    Still in progress, here is the new helm seat base. This will be the color of all the upholstery in the flybridge. All new thicker foam with bolstered sides and front, he also made the armrest longer and wider, this seat is going to be so much more comfortable.
    Spending some time on her!
    We actually have the heat on 🙄⚓️
  • IanIan Member Posts: 3,067 ✭✭✭✭✭
    I am yet to do a shakedown cruise of the Rinker and the new dink. This weather is pi$$ing me off.
    We’ve had the heat on at home a few times this week.
    Agreed. This is the worst spring ever weather wise.
    Just read in newspaper the last time Syracuse had a dry weekend, with no rain or snow on Saturday or Sunday was November 26.  26 weekends ago.
    May 20 last year
    May 24 this year, temperatures of the water in 1000 Islands (St. Lawrence River) is 48 degrees.
    That’s crazy @Spyderweb !!
    we are having the exact opposite here in Ft. Lauderdale. 91 no wind expecting storms. Its like sauna, noy enjoyable at all.
    Weekend in Westhampton!⚓️🇺🇸
    Yesterday was a decent day, warm and sunny and a slight breeze. Washed her for the first time since launch and wiped down the dust and pollen. Fitted new fuel tank fitting to hose on the new (to us) dink and took it for a few runs - what a blast, great little machine. Ended the day with a cocktail and snacks.
    Hopefully next weekend take the Rinker out for a shakedown run.
  • echandler1971echandler1971 Member Posts: 244 ✭✭✭
    New Permateek for our ‘05 360
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    Looks great @echandler1971 !⚓️
    @echandler1971 where did you order from? Coat if you don’t mind sharing?
    Local guy in NJ - DRB Marine
    cost $10k
    This guy does a lot of floors for boat dealers on new boats, so he has it down pat.
    Dan of Steel
    Almost launched yesterday.  Had a busy schedule.  Boat is 1hour and 45 minutes away.  Launch was scheduled for noon-1 pm.  After that we would drive the boat to our marina, set things up (mostly unload the car), then head back to Syracuse to catch grandson soccer game.
    Left the house at 10:15 with fully packed CX5.  2 miles from home, when pulling away from busy red light,  car starts beeping and after a few moments I realize the trunk lid had opened.  In the rear view mirror I see the Rinker bag sitting in the road as a car then runs over it.
    I quickly pull into a parking lot.  Turns out I can’t close the trunk because the locking latch is closed.  It is a push button auto open set up and I get no response from either button.  I’m thinking blown fuse.  Searched all over and could not find the fuse box.  After several attempts I rig up an extension cord as a rope to hold the door down by holding onto the loose end in the passenger seat as my wife slowly drives the car back home.
    We cancelled the launch.  Once home I figure out the way into the back of the locking mechanism, free it up and she’s all fine.  (took 2 minutes)  My blood pressure is sky high.  Will try again in another week.
    We have all been there @Spyderweb !
    Was looking over the engine bay today and noticed some staining by my new starboard circulating pump. Turns out the hose for the water heater was leaking slightly with the engine running, I tightened the clamp and it was still seeping a little bit. I went to the pump out to empty the waste tank and back to the dock. With the engine hot I was able to get almost one full turn on the clamp. Hopefully that solves it. If not, I’ll cut the hose some and try again.
    Also, I went around both engines and checked all the clamps. I was able to tighten multiple, and I just checked all of them a few weeks ago when I replaced the circulating pumps….
