Stern won't go to trailer position
No matter what switch I use, it won't go pass the safe half position.  Anyone have an idea where the problem could be?  I don't have a trailer but at the end of the season, those drive will have to go up before the marina pull the boat out.  It also worries me if I have to deal with unexpected shallow waters.
Thanks
Daniel
Best Answers
    danbrundanbrun Member Posts: 6
    Thanks for the answers, I will check that.  To answer some questions
    Yes I have twins Bravo III.
    No I never got them up, I just bought my 300 this summer and it was already in the water. But in the show room, they were up.
    I did push to the second position, but not "hard" so I will surely try that to see if this is just a contact issue.
    If not, I will check the reostat.  RinkerYan, I assume you are referring to the sender switches? http://www.sterndrives.com/supplies/mdtips06.html
    All switches, the one on the throttle handle (second position push) and the two others that control the sterns independently won't go pass the safe trim position.
    Thanks, will keep you posted!
    Dan, do you hear anything when you push harder to the second position, or is it dead quiet?
    Hi Mark, dead quiet
    Now I feel like a fool, yes, push HARD!  Very hard to get to that second notch. Nothing like the one on the throttle.  Thanks all!!  Now I can go on vacation feeling much better.
    Thanks all!!!
    aero3113aero3113 Member Posts: 8,857 ✭✭✭✭✭
    Nice!
    Did the same thing.....That's how I knew...lol
    Gary and Diane
    290 FV Nauti Bonnie
    I did it too..... welcome aboard
    rinker312rinker312 Member Posts: 255 ✭✭
    Don't feel bad. We've all been there
    Dream_InnDream_Inn Member, Moderator Posts: 7,567 mod
    oh yes, there is someone on my dock that I work hand-in-hand with on fixing things.  He didn't know that pushing hard did that. So don't feel bad.
