1126128130131132
  • YYZRCYYZRC Member Posts: 5,351 ✭✭✭✭✭
    edited June 2
    Maybe you wanna hit those brass fittings w some Merc black paint? You are slippin’ @aero3113. I expect better from you.
  • aero3113aero3113 Member Posts: 9,482 ✭✭✭✭✭
    When I installed it I said to myself I should polish it. I convinced myself not to do it! ⚓️
    As @mattie says: the way you do one thing is the way you do everything. No way you are gonna get a good sleep tonight after this.
  • IanIan Member Posts: 2,965 ✭✭✭✭
    One of my start of season tasks it to go over all - over 3 dozen. Each gets 1/4 to half a turn.
  • Rich_Rich_ Member Posts: 246 ✭✭✭
    Been a while since updates. Got one Whaler floating last week, one more to go.
    On to the big boat- got fresh water system unwinterized and 1/2 way through new risers/elbows. Hull is waxed and just did bottom paint today. Getting closer.
    Been busy car shopping for the Mrs (picked up a GLS450) and next week have a festival to get ready for so time is a bit scarce
    Driving down to the boat today I remembered that there were a couple of clamps I forgot to check. First one kept skipping and wouldn’t tighten, second one the head came off as soon as I tried to tighten it! Glad I remembered these!! Didn’t have spares the size I needed so had to run to the hardware store and pick up a few.
  • Aqua_AuraAqua_Aura Member Posts: 2,683 ✭✭✭✭✭
    Got the new upholstery in the flybridge. The flooring is supposed to be done in a couple weeks which will tie everything together.
    Also if you notice, the boat is in a boathouse. Our friend sold their boat and I am hoping I can buy this from him but for now we are just using it while he's boat less.
    @Aqua_Aura
    Good job on the upholstery. Modernized the boat. Assume it was all white beforehand??
  • captkevincaptkevin Member Posts: 384 ✭✭✭
    Nice work Aura Aura looking good
    Looking good @Aqua_Aura !!⚓️👍🏻👍🏻
    edited June 17
    I guess I didn't delete the photos, this is what it was before. Really worn out foam and discolored white vinyl. New stuff has 3" and 4" foam under the thigh area.
    Post edited by Aqua_Aura on
    Huge improvement
    Agree, huge improvement. Looks great ⚓️
    Holy - huge difference!
    Was snugging up a clamp and it broke. Crazy how many I’ve had to change this season so far. Check them!⚓️
  • FormulabenFormulaben Confirm Email, Member Posts: 174 ✭✭
    Is that a custom hard shade for the portlight, the white thing?
    They came with the boat from what I know. It is just a plastic cover over the port hatch.
    Floated today. Still have to wash/wax topside and get the other Whaler in (and then on to the Waverunners)
  • echandler1971echandler1971 Member Posts: 231 ✭✭✭
    edited June 28
    I added an ugly cat  to my radar dome today. Owls ain’t cutting it anymore. Seagulls are getting smarter around here. I’m tired of daily shitzkriegs on my canvas.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    edited June 29
    My windows have really bad hard water spots and I have tried two products that work really well and wanted to share.
    The first one is for mild water spots that aren't etched in. It's a gel you put on and leave for about 15-30 minutes then wash and clean the window.
    https://www.chemicalguys.com/products/heavy-duty-water-spot-remover
    This is the second product I used which is a window polish you apply like your buffing a boat. This works really well for etched in water spots which is what I have on my side windows. You use a polishing pad specifically for this process, it looks like white felt.
    https://www.griotsgarage.com/fine-glass-polish-16-ounces/
    Good to know, thanks @Aqua_Aura !! ⚓️
    First overnighter of the season. Had to anchor because somehow the mooring ball that was there last week is no longer on the mooring. I did find the chain and the old swivel was gone but last fall I put a new one in parallel with the old that was still there so not sure how the shackle would have come undone. Replaced the upper chain and put a temporary float on it. All went well except for stubbing a toe on the dock. Will have to stay away from the dock longer next time.
    Got the Sea Fox fixed up and ready for sale. Took it for a shakedown cruise today and she ran like a champ!
    Looks good YYZRC
  • rasburyrasbury Member Posts: 8,663 ✭✭✭✭✭
    Quiet, which means everyone is using their boats! It's been to hot here in fl...
  • SpyderwebSpyderweb Member Posts: 942 ✭✭✭
    @Aqua_Aura I have used the griots garage polish on my etched car windows and it works fantastic.
    Was looking things over after a 5 day trip,saw a lot of water in the mid bilge. Vacuumed out over 5 gallons. I found the fitting for the AC drip pan broken.
    I was able to use an easy out to get the broken threads out. It originally had a straight fitting that must’ve been resting on the base and caused it to snap. I looked for a 45 but couldn’t find one and used a 90, much better. I used clear vinyl tubing because it was much easier to work with in the tight area!
    She’s flowing!
    It’s crazy how much condensation the ac produces!
