342 Shower sump replacement
Hi all - started up the water system on my 04 342 for the first time in a few years and the shower sump needs to be replaced.
Has anyone found a replacement that fits? Went and grabbed a rule from west marine and unfortunately was too wide.
I plan on keeping the shower box but only for the AC conversation and bleed lines.
I fill a pan with water and warm it up on the cooktop. Turn on the galley sink and run hot tap water down the drain for a few minutes. Then dump the pan of hot water down the sink.
I am actually having an issue with my sump pump. The pump itself comes on, sometimes it pumped water out, sometimes it would come on and not pump water out. The float seems to be working fine, so I replaced the pump with the same Rhule model, figuring that would solve the issue. Nope, does the same thing. The pump always comes on when the float comes up…but sometimes it pumps out water and sometimes it doesn’t. Nothing seems to be blocking the water drain because when it pumps out, it takes the water out immediately. If I keep hitting the float up and down, it will finally start to pump. I'm stumped. Maybe the gulper is for me.
The install was just remove sump box replace with Gulper. I added a switch in the head (proper Vimar brand switch to fill the blank).
Whale BP1552 Gulper 220 Pump,... https://www.amazon.ca/dp/B000FHQL5G
