342 Shower sump replacement
McGarnicleMcGarnicle Member Posts: 260 ✭✭✭
Hi all - started up the water system on my 04 342 for the first time in a few years and the shower sump needs to be replaced.
Has anyone found a replacement that fits? Went and grabbed a rule from west marine and unfortunately was too wide.
  • IanIan Member Posts: 3,059 ✭✭✭✭✭
    Is it the pump? I found mine was an issue and it was the solid state float, not the pump.
  • aero3113aero3113 Member Posts: 9,761 ✭✭✭✭✭
    If the original sump box is still useable, just replace the pump in it.
  • PickleRickPickleRick Member Posts: 4,333 ✭✭✭✭✭
    edited July 2025
    I've read a few guys on hull Truth replacing the sump box with a whale gulper. Theoretically it won't get clogged by hair/soap.  Just turn the switch on while showering.  I just replace my overboard macerator with a whale gulper this week.  I pump out at the launch ramp RV campground.    This is my next upgrade.  I'm tired of cleaning soap scum from the shower box and hair out of the inline screen filter.  I want less maintenance from my boat.
    I plan on keeping the shower box but only for the AC conversation and bleed lines.
  • YYZRCYYZRC Member Posts: 5,403 ✭✭✭✭✭
    I have the whale gulper as my shower sump and it’s awesome. Only drawback is that it’s a bit noisy.
  • LaReaLaRea Member, Moderator Posts: 8,060 mod
    I use a monthly hot water rinse to liquify whatever grease/soap might be in there, so it gets pumped out.  Haven't had a problem since I started doing that.  And that's a single sump tank for 2 showers/sinks, washer/dryer, dishwasher and galley sink.
    I fill a pan with water and warm it up on the cooktop.  Turn on the galley sink and run hot tap water down the drain for a few minutes.  Then dump the pan of hot water down the sink.
  • raybo3raybo3 Administrator Posts: 5,614 admin
    I use white vinegar and let it sit. Works great
  • johnny44johnny44 Confirm Email, Member Posts: 136 ✭✭✭
    @YYZRC can you give me more information on the whale gulper please. What model? Did you install...was it a simple install?
    I am actually having an issue with my sump pump. The pump itself comes on, sometimes it pumped water out, sometimes it would come on and not pump water out. The float seems to be working fine, so I replaced the pump with the same Rhule model, figuring that would solve the issue. Nope, does the same thing. The pump always comes on when the float comes up…but sometimes it pumps out water and sometimes it doesn’t. Nothing seems to be blocking the water drain because when it pumps out, it takes the water out immediately. If I keep hitting the float up and down, it will finally start to pump. I'm stumped. Maybe the gulper is for me.
    Former Boat: 2008 350 EC
    Greenwich Bay, Rhode Island
    edited July 2025
    I had that issue with the Rule - I removed the backflow valve and then it worked fine. Remove the fittings on the sump box and check if yours has the valve installed.
    The install was just remove sump box replace with Gulper. I added a switch in the head (proper Vimar brand switch to fill the blank).
    The Gulper would be one of my first mods if I get a different boat. Highly recommend.
    Post edited by YYZRC on
    @johnny44 Gulper BP1552
    Whale BP1552 Gulper 220 Pump,... https://www.amazon.ca/dp/B000FHQL5G
    A question about why you ran power from the vacuflush…couldn’t you just tie in the power that was there from the sump pump already without having to run a different power source? There is a breaker for the sump pump.
    Sorry, youre right, I am mixing up the Gulper project with my Vacuflush timed switch.
  • SpyderwebSpyderweb Member Posts: 955 ✭✭✭
    @YYZRC has had a LOT of projects.  Eas
    Easy to get confused
    Anyone ever see these sump tanks. @LaRea, do you have this on your boat by chance?
    https://trioniccorp.com/products/shower-sump-tanks/2-gallon-12-volt-marine-supersump-r-shower-sump-tank-st-6075
    @johnny44 - mine is around the same size but it has a mechanical float switch and an external pump.
  • McGarnicleMcGarnicle Member Posts: 260 ✭✭✭
    Thanks everyone. Unfortunately, the shower ended up being the least of my worries since shortly after creating this thread I blew my starboard motor up lol
    Oh no!
    Sorry to hear that @McGarnicle
    How did it happen?
    We think the head gasket blew which then caused it to melt the piston. Crazy thing is the temp gauge never went above 180F.
    Have a long block getting here next week and shouldn't be down too long.
    @johnny44 not sure where you landed on this but wanted to give a heads-up - I hooked the Gulper up to the black corrugated bilge style hose that was original to the boat. Last weekend that hose cracked and caused my shower to leak into the mid bilge.
    Highly recommend upgrading the hose from the sump/Gulper to the thru hull.
    @YYZRC , check valve...after all of that, I removed the check valve and wouldn't you know, all is fine. That little check valve seemed to be causing all of the problems (and it is a brand new one too). I really like the new Rhule sump - it’s easy to clean, simple. I can’t believe that all of the issues I had were from the check valve.
    Glad you got it fixed for 0 boat bucks!!
