Radio replacement
rasbury
Member Posts: 8,909 ✭✭✭✭✭
My music radio has been touch and go for some time. I had in my boat bag the radio info but it must be in the boat. It has an amp also that was factory I believe. Couple of questions-
I assumed these are just an auto type radio correct? For replacement, what does the radio use for an antena? I want to get something with at least one remote. It has one by the swim platform but being a 270 I can live with just the helm. If anyone has something left from an upgrade they would care to sell I'd be interested. Any recommendations would be good to. The amp is located on top of the TV cabinet and the radio is in the face of the cabinet.
For amp I'm using a little taramps 90 dollar amp to push mids/tweeters. Use much bigger second amp if I add subs. Amp from Amazon, lots of good reviews.
Powers two 6.5s, four 4s, and two 1 in inch tweeters my my yota. Very clear at high level to combat the soft top/road noise.
Thinking about doing the same in the Bayliner.
Just put a similar setup in the admirals Delsol.
I'm running cheap pyle 4 and 6 inch bar mounted pods. I figured I'd replace the crap speakers with some better speakers later but nearly 3 years of abusive daily driving I haven't blown one yet...knock on wood. I really just wanted the pods to hang from my roll bar.
If i can just change out the radio head and have one remote at the helm I'll be golden. The speakers sound OK, it does have an amp that i hope I can use- i can tell the difference in sound from a better system- but it's just not a priority for time or $$ to really up grade the system. My truck had been ordered with a big amp under the rear seat and I enjoy the great sound- ford stuff I always thought sounded good. If I can swap the head, wire in a dash remote I would be so far ahead of where I am at- it never really worked well. I think it is an auto type- I've pulled it apart and cleaned connections and button contacts with some success but I'd like to spend that time doing other things!
Thanks if you have any tips- i found one, I think, on ebay and will attempt to post a link. It looks like it's need to confirm the cut out size- I've read the DIM (or some other code) controls that size but it does not sound like on older boats there would be as many choices.
https://ebay.us/m/G7XcdF
On the Passat I had to call their tech line as I had some questions that they cleared up quickly.
Their factory amps are more like crossovers than actual amps, but either way they sounded good and didn't need upgrades other than the head unit.
Thanks again- Rick
It comes with a wireless remote. You can control everything with the remote. My Amp was fried so I just didn't even bother to hook it up. Its plenty loud enough for me.
I put a little electric grease on the wire tips before crimping.
Get some good heavy duty Kline type crimpers.
You can't glob it on like a fat kid would want his Hershey syrup on an ice cream sundae, you just put on a light coat.
It will not hender your electrical connection when there's metal to metal contact like a battery terminal, crimp or spade connection.
We can also argue things like which oil is best or is crimping superior to soldering. There's no single correct way.
On the stand on/ride on fertilizer sprayers, if we didn't grease every electrical connection there would constant electrical issues in every system.
Even some outboard manufacturers will tell you to apply grease at the connectors.
