Battery discharge
rasburyrasbury Member Posts: 8,738 ✭✭✭✭✭
I always seem to have dead battery issues...I made sure I had the vhf off- nothing on and start battery is dead, house seems fo be fine. I've read this could possibly be something to do with the alternator? It sat for about 3 weeks...
  • IanIan Member Posts: 2,990 ✭✭✭✭
    Mercathode?
  • captkevincaptkevin Member Posts: 437 ✭✭✭
    How old is battery?
  • rasburyrasbury Member Posts: 8,738 ✭✭✭✭✭
    I put two new batteries in probably 2 years ago..Just old leaders...I've only run it a couple of times. All the wiring I'm sure is orgional...including the alternator.
    edited September 6
    You could take the batteries to be tested or just disconnect them if you're going to be gone for awhile and see how they work when reconnected. If they are dead then it's the batteries. If they work fine then there must be a draw from something.
    Have you methodically gone thru everything to be sure what you think is off is actually off. Is the boat connected to shore power and being charged? If you're not on shore power I would shut the battery switch off. Your bilge pumps should still be powered on this situation.
    edited September 6
    Yes @Aqua_Aura best I can. It's a 270 so not lots of add on things other than factory. I turn off the battery switch always. Bilge and vhf are the only things I see staying on...
    I would disconnect the negative on the batteries then and see what happens or take them to be tested. Just my 2 cents or maybe it's 5 cents now with inflation 🤷🏾‍♂️
    I see you said it's just the start battery. I missed that the first time. The alternator could have abad diode. I actually had this happen on my Chevy Tahoe and you can use a test light to check it. With the batteries on you can check across the alternator and if it lights up the diode is bad. Look it up on YouTube and you'll see what I'm talking about, I'm probably missing some finer details. Basically you get a draw off the alternator because the diode is allowing power the wrong way.
    This actually happened when my wife was out of town by herself camping and she diagnosed it based off may same advice of the diode and she replaced it by herself parked out in the woods 😊. I forgot about that story and solution until now.
  • Lake_BumLake_Bum Member Posts: 1,090 ✭✭✭✭
    So......you have a Perko switch that you shutoff every time, and the batteries are still dead?  Weird.  Unless you're talking several months inbetween starts.
    Thanks for the input..@Aqua_Aura that's kind of what i had read- but figured way over my head to figure out- I'm rethinking that and will look. @Lake_Bum today it was just the starter battery- not sure how much juice was in the house. It was probably about a month since it was out. Most of the time the spans between use were pretty large. They seemed to have charged and will run the river a bit am...
  • PickleRickPickleRick Member Posts: 4,221 ✭✭✭✭✭
    edited September 8
    Do you not have auto bilge pumps (turn on every few minutes) and CO2 detectors that are always on even if the switch is off?
    That alone could draw down batteries over a few weeks.   Excess heat or cold makes batteries discharge at an even faster rate.
    Years ago I could leave my group 31s all winter from October til May without issues so long as I charged them before storage.  Now my batteries these days don't last more than two seasons if I do that.  Back when the admiral and I had a 21 ft sailboat and porta potty our first summer together all I could afford were free lawn mower batteries pulled out of scrappers to make our little battery bank...wasn't ideal but those 6 batteries lasted us for 3-4 seasons and I never had more than a 50 watt solar panel to charge them. Battery quality sucks these days.  You guys have dingys with more horse power than the kicker motor I kept on the back of that little boat.
    I think my current banks is one 31 and two 27s...I can't remember as they are at least 3 years old.  I never turn off by perko switch but I make sure the shore power is always hooked up.
    Do you have the ability to add a solar charger.
    I'm on a trailer and my 02 are battery. Just replaced them- non replaceable battery and 10 year guarantee. I have no clue just bouncing things around!
    edited September 8
    If you don't have the ability to hook the boat up to shore power to make sure the batteries stay topped off a solar panel might come in handy for your application so long as no one decides to take off with it.
  • FormulabenFormulaben Confirm Email, Member Posts: 186 ✭✭
    FWIW, I got rid of the battery isolator because it was leaking current to the other battery. Also, I swapped out the standard bilge circuit breakers for circuit breaker switches, so when it's in storage and the battery switch is OFF, I can also flip the bilge switches to OFF, and then there is ZERO power going anywhere. (And yes, this also includes the interior fridge, which I put in a hidden power switch under the sink.)
    Here is the C/B I used:
    https://www.digikey.com/en/products/detail/sensata-airpax/T11-1-15-0A-01-11C-V/8509109
    Thanks all...I'm leaning towards alternator.  Bat one was dead this am - but the charger was off. It started on bat 2. I have a little plug in gadget, not sure how accurate it it but it was warning charging volts was less than 13.2 and the dash gauge looked about the same- forgot my meter. When I first started, it was not showing charging it all. I did launch but never turned it off. Ran for a couple of hours. Back at the doc, bat one did not charge. I did restart on bat 2. It has been showing almost 14 volts on the gauge.
    Should I be checking connections? Can an auto parts bench test it? If it were my car I'd just replace it, I'm guessing this one is pricy...but I'd like to make sure before I do that...
    You can get a cheap one from db electric but an auto parts store should be able to test it, tell them it's from the same year Chevy v8 pick-up as your boat.  Hopefully they won't know painted black means marine
    If the alternator is bad wouldn't it not charge either battery? Makes be think battery is bad
  • YYZRCYYZRC Member Posts: 5,359 ✭✭✭✭✭
    Buy a DB Electric. Great product.
    edited September 9
    Those prices are not bad at all- car like price.
    They are located (or at least were) in Tennessee so east coast ship times are pretty good
    I'll get it pulled ans checked- it's probably about due so I don't think it will repair it.
    edited September 25
    I pulled the start battery and brought it home for charge and testing. Did not make it to testing. The charger went to 15 amps....thin after a few seconds went to 0, back to 15 and then a braker in the charger kicks out. So that is toast...the other battery raised and lowered the hatch with the new switch installed. I will replace, charge the other battery and do more testing on the alternator via chat gbt. Also had ideas to see if there is a parasitic draw.
    ** forgot to mention...I thought odd..with what i presume battery one is removed, when I went to lower the hatch it would only work if the battery selector was on both- would not work on one or two?
    Post edited by rasbury on
    I went back to the boat and pulled battery two. It raised the hatch with it and closed it with my jump box. It's charging here at the house. I had invested 45 bucks at harbor freight for the tester so will see where this one lands- then hopefully have some warranty on the dead one.
    edited November 12
    Some results-
    No warranty on battery 1.
    My tester showed battery 2 is ok.
    I put the new battery and the good one back in today. GBT gave me a procedure to remove the negative cable and check for amp between the terminal and the cable. . Battery 2 which I don't seem to have as much problem with was a dead 0. The other battery is .10 which would kill the battery within a week or so which sounds about right. I pulled the power wire off the alternator and checked again with the same result. That should rule out the alternator with a bad diode .
    So, I've left the negative off that battery until I come up with a plan to figure out the draw. I still do not understand that with battery 2 in and all hooked up the hatch will not work. The trim works, the engine turns on. I had to close it by using the jump box on the terminals at the battery switch. With the completely dead battery still hooked up, the hatch would raise on battery 2. Remove battery one and does not work. Not that I'm going to worry about it now- just seems odd. I have other things on my list to get done. I'll just have to hook that battery up at the ramp. I assume normal charging while running or on shore will keep it up and the draw during a day out won't kill it.
     Update: as far as the hatch, it would have helped if I had turned on the accesory switch by tge battery selector.  It does beg the question,  things that are hot all the time like the radio and the bilge- would they run off battery one ? If it is dead, will the bilge still run off two somehow? I imagine this system is a little complicated than a novice like me will grasp. Searchlight? I tried it yesterday, I put a new control head on it, but nothing would come on yesterday with the negitive off bat 1. I did not try the radio but I will play with tgat a bit. We are only up to 55 today- might be in the water on Friday.
    If I'm understanding chat gbt, it suggests hooking the meter between the negative terminal and the cable end and start pulling fuses. I know i have the push button type but to be honest I've never had a reason to pull one- I assume it's a glass tube type with a filament? I can unscrew the face and pull them? I think a couple of more by the battery switch, any more? I don't think there were any updates to the boat for the first owner.
    edited November 12
    Ras, you have the 270 like I do.  Can you unscrew the battery box and take a picture of the wiring behind it?  I did that so I could "map" the wiring...I was able to find which items were on the "hot" bus and which ones went through the battery switch.  You may have some electrical parasites you are unaware of...
    Thanks @Formulaben - perhaps if I post a picture someone can give me some guidance.
    I am having an issue with the sump pump in the shower. It's  locked up. The box is also full of water , i wonder if that pump is wired hot like a bilge? Since the float is trying to turn the pump on, could that be my draw? Im going to cut the pump and will test the wires for power with everything off. I probably won't have time to deep dive in this now but will have to get back to it.
    100% yes on that, as it is part of the bilge pump circuit. If the float is stuck "up" or if it is full and cannot pump it out it will definitely drain the battery.  I really wish Rinker would have put a bilge status light at the helm to annunciate a running pump, but that's a different conversation...
    If your sump is full of water and the pump is on, that tells me you either have a clogged hose or the impeller of the pump is clogged with debris; in this case you won't hear it running at all, but it will have a draw on the battery.
    FWIW, I bought a brand new sump with pump because mine had a small crack in it...have a new one brought me some peace of mind.
    https://www.amazon.com/dp/B01N1FHKQI
  • aero3113aero3113 Member Posts: 9,587 ✭✭✭✭✭
    @Formulaben I installed a low profile bilge pump right at the drain plug. I think I used the wiring/switch for the “swim light” since it wasn’t being used. I changed the switch cover to say “AFT Bilge”. When the pump turns on automatically, the switch lights up. It is nice to see when it’s working.
    edited November 15
    I'm not that smart @aero3113...I'm lucky I have not blown the boat up. Had a nice little run today!
    I checked the amp draw at the ramp. I had cut out the shower sump motor. Before I replace, sounds like I should try to break the motor loose before I replace...but the amp draw was still the same. Something with everything off is pulling 3 to 4 amps with everything off.
    edited November 15
    Yesterday was the most perfect boating day..about 75, glass and not a cloud in the sky.
    So, to recap ...
    I did recheck at the ramp bat 1, interesting to me was with the engine off and checking the amps, it did not matter if bat switch was on or off- same draw of 3 to 4 amps.
    Non working sump motor removed.
    I did confirm with tester both batteries are getting high 13 and low 14 charging from the alternator. When I first cranked it up the alternator was not anything and glancing at the gauges a few minutes later it was showing 14.
    What would be the amps running down the river? I assume running the alternator can overcome this draw?
    Are you asking why it wasn't charging then suddenly charging?
    If so that's normal from my experience, while my engine is a diesel it uses a common GM alternator. It won't put out charge until I bump the throttle.
    Was the ignition switch on when checking the amp draw at the ramp?
    How about the battery switch?
    Just your radio and amp turned on, not playing will draw amps.
    I would be looking for the source if your test was done with the battery switch off.
