Genius or to lazy?
rasburyrasbury Member Posts: 8,712 ✭✭✭✭✭
I had to post this...i walk my neighborhood every morning. I've been watching the progress of this mail box repair.
My neighborhood is mid level middle class - 350k or so homes. Now my neighbor I've been watching, has a neighbor next door  ..
Then, you have this picture..you have to zoom on it to getvthe full effect..
  • PickleRickPickleRick Member Posts: 4,220 ✭✭✭✭✭
    Assuming he's had his mailbox knocked down a time or two?
    Or he hates the HOA
  • rasburyrasbury Member Posts: 8,712 ✭✭✭✭✭
    There has to be a back story- it's a decent home in the neighborhood,  has a late model expedition in the drive...been like this for years- if you zoom on it, it's just a rotten piece of wood that will no longer hold a screw!
    edited 3:40PM
    If it was a beaten mailbox issue, a 6 inch thick wall steel tubing, painted brown to look like wood 4 ft deep with a 12 inch hole for concrete is a good start.
    Welded to the steel pipe is the largest square tubing you can find that fits inside a standard sheet metal mailbox, trussed.   You'll have to notch the bottom out of your new mailbox to place it over your square tube.  Attached with 1/4-20 screws.
    The poor soul who decides to hit the mailbox with a bat will feel it for days.   The poor soul who hits it with their vehicle will need to call AAA.
    This is also good for plow trucks, although I'd go 6-8 ft deep and 8 inch tube for plow trucks.  Also  double the hole size for concrete.
    For added strength fill round tube with concrete.  Bracing concrete with rebar/mesh in the hole is also a good idea if  you need stopping strength.
  • captkevincaptkevin Member Posts: 421 ✭✭✭
    Very interesting mailbox
