Wifi Cameras....
oscar1oscar1 Member Posts: 804 ✭✭✭
I am finalizing my starling installation, but i would like to ask if anyone in here have a recommendation for wifi cameras which it can be connect to the starlink internet for security and remote surveillance of the boat at the marina. anything will be appreciate. thx
  • IanIan Member Posts: 3,077 ✭✭✭✭✭
    I use a Blink.
    I have four of these cameras:
    https://www.amazon.com/dp/B0BX25NGCK
    It's power-over-ethernet, which makes it easy to install.  It has two cameras that combine for a single image over 180 degrees field of view.  To the software, it just looks like a single camera.  The image resolution is good, but not great.  You can't read license plates unless it's close.  But it covers a wide area, and they have held up well in the marine environment.
    They are cheap compared to marine cameras.  I have a spare in case one breaks.
    I have Arlo which they say are compatible with Starlink
     One consideration is that they all need power. The Arlo can be hardwired or recharged. The Blink has longer lasting batteries. They both have motion detection and the Arlo will trip with sound as well. The more they trip the faster the batteries run down. So you don't want them where they capture anyone who walks or drives by the boat. The Blink are much more affordable.
  • aero3113aero3113 Member Posts: 10,041 ✭✭✭✭✭
    I use a ring stick up that has a hard wire plug but also has a battery if power is lost at the dock. I have a wifi extender router that I use and it’s powered by 12 volts. This season I might install Starlink so that might change.
  • grouch0jrgrouch0jr Member Posts: 265 ✭✭✭
    Anything innovative here? My marina has wifi but my slip is very far from the hot spot, so it's spotty at best. I was thinking about getting some sort of antenna/booster/whatever.
    @grouch0jr
    This is what I use, looks like it’s upgraded. Mine is V2
    https://a.co/d/1JdOHt8
    Home depot was running a very good deal in starlink mini $229 and standard $279. I got the standard because I was going to install it flat on the hardtop with a trio mount. I will post some pics after it is done.
  • YYZRCYYZRC Member Posts: 5,555 ✭✭✭✭✭
    edited December 2025
    I had a Ring in my Rinker but just changed it to an Arlo so that I have my home and boat camera on the same account. Arlo indoor generation 3 was $23 Canadian on Amazon.
    US Amazon pricing as of today. I have both Gen 2 and Gen 3. Only difference I can see is that Gen 3 has a USB C in the back vs Gen 2 where the wire is permanently attached.
    @oscar1 man, I could've gotten you that Starlink standard for FREE with my referral!  And a free month of service too haha.  Oh well lol.    I love our Arlo system for Wifi cameras.  Lots of options, although the newer versions, they try to get you on a subscription plan, but it's not necessary on the older ones.  Free access to cloud recordings.
  • J3ffJ3ff Member Posts: 4,244 ✭✭✭✭✭
    Wyze is the best per dollar...
  • echandler1971echandler1971 Member Posts: 244 ✭✭✭
    I use 4 Arlos - all battery type. They run off of my Mifi. The batteries need charging maybe 3x per 6mo season. I have 2 in the cockpit, one in the cabin aimed up the breaker panel, and one in the engine bay, catching the battery charger and engines. I've caught the occasional raccoon or otter that came aboard. I was able to then use my SirenMarine to set off the alarm to scare them away.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    I capture Deer & Elk almost every night on my Arlo system at home. I use the solar on a few
