What is gear ratio for 2002 350 Mag Bravo3 stolen - any non-OEM replacements
SoSweet
Member Posts: 10 ✭
Dang Pirates made off with my Bravo 3 outdrive. Looking for non-OEM replacement suggestions and gear ratio?
Post edited by LaRea on
I'd check mercruiser registration to verify gear ratios.
Since you're on a lift you can test the water tightness of your plate before towing. Just dip it in to see if it takes on water. And make sure your bilge pumps are powered up - and/or have the tow operator put one of their dewatering systems in place just in case it's needed on-the-fly.
good thing you saw it was missing before you lowered it in the water.
https://www.sterndrive.cc/product/Fits-Mercruiser-Bravo-Three-Complete-5441500TP.html
Any chance your insurance will help you out with a loss via theft?
