May need some help........
oscar1
Member Posts: 804 ✭✭✭
I have the following problem which it become frustrate at this point. as the following photo i have an alarm about the trim limit. i replace both trim limit in both engine, clean every ground connector for the engine, as following in a forum I replace the engine mecathor system. after everything done i still getting the following alarm intermittent now. it mean it happened sometime when i start the engines and sometime when i am running the boat and something it doesn't happen during my trip..IT is real frustrated because i don't have any clue what can be causing this issue. I was told to replace the harness which connect the engine trim sender and maybe the herm control too. any advice or if anyone have this issue before will be appreciate. One more note my mechanic can not figure the issue too. Thanks
I recall you asking about how they are replaced so assume this was not a new problem....if you are not at a mercury shop I'd look at what's making the noise as the problem!
(Values for ohm meter testing -- 10-167 ohms across the 2 wires. )
With a Multi meter on ohm setting with leads in plugged into correct positions ( verify meter work by touching leads together and getting something close to 0 ohms on meter indicator )
Connect the meter leads to the 2 trim sensor wires ( These should be disconnected from boat )
Spin the sensor housing to center section & look for readings that are variable as it turns and in this range.
Crimp some bullet connectors on each end and plug it into your trim wire. Heat shrink for a little added safety
Assuming your wiring from the connector up is good, this would leave the vessel always seeing the drive at the down position.
I've never used resistors for this purpose but they work amazingly well for fooling vehicles into making LED signal bulbs achieve proper resistance so the blinker relay doesn't click a million miles an hour.
Watch your drive at low tide and around coral heads!
