Hard to start
GMSLITHO
Member Posts: 1,626 ✭✭✭✭
Had some issues with the boat last year it would bog down at high idle so I replaced everything ,new plugs wires rotor and cap ,had the calibrator rebuilt and replaced the fuel pump it was running great but the only issue is with a cold start it wont start up I can start it with a little hot shot and when it warms up it will start all day no problem .I can take off the arrestor and when I pump the throttle with the key off I dont see any fuel shooting out of the jets >Im beginning to think the fuel pump I bought sucks , I se they sell a high pressure BOOST pump I reall cant thing of anything else its a 5.7 1999 240 Fiesta Vee
They out source most of their carbs like what are found on your boat to a gentleman in his upper 70s/early 80s.
The only time in his life he didn't work on carbs was when he was deployed during the Korean war.
If you want a carb done right, ship it to him. I ran a Chevy V8 for a few years on an fj40. We rarely get temps in the teens down here. During a cold spell of about a week of 6-10 degree overnight temps I could run out to the yota, pump the pedal 3 times. I'd bump the key then run inside for 10 minutes while the vehicle warmed up.
If you're looking for recommendations of a carb done right. Back then it was about 250 bucks for a rebuild @ 2015.
