No Power Issue - Need Help Diagnosing
My 2013 276 Cuddy is having an issue. I hooked up the three batteries like normal and I'm getting zero power sent anywhere, except for the bilge pump. That turns on and lights the dash button like normal.
I've checked every fuse and breaker I could find and no luck.
Any ideas where to start? Am I right in thinking not likely an ignition switch issue, because I dont need the key in to work the lights or some other accessories, which have no power.
Would a bad battery switch cause what I'm experiencing? If it wasn't sending power when I change positions it could always act like "OFF" right?
2013 276 Cuddy ~ 350 MAG / B3
I'm guessing the switch is on the way out, so I'm going to replace.
Smart move. Problems don't ever actually fix themselves, haha.
