No Power Issue - Need Help Diagnosing
JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
My 2013 276 Cuddy is having an issue. I hooked up the three batteries like normal and I'm getting zero power sent anywhere, except for the bilge pump. That turns on and lights the dash button like normal.
I've checked every fuse and breaker I could find and no luck.
Any ideas where to start? Am I right in thinking not likely an ignition switch issue, because I dont need the key in to work the lights or some other accessories, which have no power.
Would a bad battery switch cause what I'm experiencing? If it wasn't sending power when I change positions it could always act like "OFF" right?
2013 276 Cuddy ~ 350 MAG / B3
  • JoeStangJoeStang Member Posts: 1,144 ✭✭✭✭
    Also, I am able to life the hatch up & down as designed by connecting a battery directly to the "hatch override" terminals. So it seems like power works for the two items designed to be used with direct power.
    edited April 21
    I've had two battery switches fail on my 2011 boat.  The backside plastic bits crack, and then there's no pressure holding the connectors together.  Take that panel off and look for obvious physical damage on the back of the switch.  If there's no obvious damage, check continuity with a multimeter.
  • GrahamuGrahamu Member Posts: 923 ✭✭✭
    edited April 21
    It's not the ignition switch and the bilge pump(s) by-pass the main battery switch The breakers with yellow tags, are they not supposed to be closed so they are not visible.
    Yeah, I was cycling those yellow breakers when I took that pic, none had tripped themselves.
    I took the rear plastic cover off behind the battery switch and everything looked snug, but its an annoying spot to see well. I'll be going back tomorrow to take another stab at it. I'll take my multimeter too.
    I assume if I dont see continuity from one terminal to the other with the switch "ON", that means the switch is bad, correct?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    Yes, if you do not see continuity or voltage then it is the switch.  Definitely the first place to start. My son just changed his out on his boat this past weekend.
  • captkevincaptkevin Member Posts: 617 ✭✭✭
    Did you reset the main breaker on top of the motor?
  • raybo3raybo3 Administrator Posts: 5,623 admin
    Are you positive you installed all the wires going to the batteries? A friend on mine had the same problem and found that he didn't connect the all the D/C neg wires.
    What changed, did you have the batteries out and re installed? Go back through your steps for what ever changed..
    So I came back the next day to do some more diagnosing, and everything was working correctly! I didnt change a thing....
    I'm guessing the switch is on the way out, so I'm going to replace.
    Smart move. Problems don't ever actually fix themselves, haha.
