E15 fuel
GrahamuGrahamu Member Posts: 921 ✭✭✭
Just read that E15 gasoline will be available in the summer in the US. It is prohibited by law in the USA for use in marine engines.
  • IanIan Member Posts: 3,069 ✭✭✭✭✭
    Premium doesn’t usually have ethanol in it.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,954 mod
    Not true, it can still be and usually is E10.
  • captkevincaptkevin Member Posts: 583 ✭✭✭
    Majority of premium in our area has ethanol. For the price you would hope it would not have it.
  • PickleRickPickleRick Member Posts: 4,388 ✭✭✭✭✭
    edited April 26
    A majority of ethanol free fuel in our area tests positive for ethanol.
  • Rich_Rich_ Member Posts: 354 ✭✭✭
    Only way here to get non ethanol is buying AvGas (aviation gas). And you thought it sucks to put premium in the car, try filling a boat with AvGas  :#
    I wonder what the methodology of the testing was? Watched a news report that showed since the majority of gas pumps used shared supply lines you have to clear the line back to to the junction before taking a sample. People were getting a lot of false-positives because they didn't do the testing correctly. When we go to Iowa there are a couple of Casey's that have pump islands with dedicated hoses for each fuel type so you can guarantee no cross-contamination.
    Along with fuel islands, you need tankers dedicated to non ethanol.
