Seawater Pump Pulley Removal/Install
grouch0jrgrouch0jr Member Posts: 232 ✭✭✭
After dropping in this past weekend, I noticed one of my seawater pumps is leaking a bit. I'm getting ready to do the replacement job for the first time. I've already bought the pump I need (this one), but I need to buy a 'power steering pulley removal/install tool set' in order to swap the pulley onto the new pump. I've seen conflicting information on what kind of set I need. Some sources say I need a metric set, and others saying I need one compatible with GM (and these appear to be SAE). Does anyone have any guidance or recommendations on which tool to buy?
  • LaReaLaRea Member, Moderator Posts: 8,069 mod
    From the diagram, I think it's the same Lisle 39000 "no slip" pulley puller that I bought back in the day.  I still have it ... if you want it, I can ship it this week.
    I can tell you from experience -- regular 3-jaw pullers won't work.
  • grouch0jrgrouch0jr Member Posts: 232 ✭✭✭
    This looks perfect. Thanks but I'm going to order one from Amazon so I can have it tomorrow. Thanks!
    Yes, I’ve tried it as well.
  • PickleRickPickleRick Member Posts: 4,371 ✭✭✭✭✭
    If you're in a need it now pinch most automotive stores rent a power steering pulley puller kit
    edited May 7
    Pressing it back on will be the next challenge.
    That tool does removal and installation.  Easy peasy.  But it only works with that specific style of pulley.
    So I got the pulley off using Lisle tool no problem (with a little help from an impact gun). I was missing some other tools on the boat so I didn't get to wrap up the project yet, but I also am worried a bit about water ingress while swapping the pumps. I have thru-hulls for the water pump, but when I close the sea cocks I think water still comes in through the bravo drives. I tested this by opening my sea strainer, and even with the sea **** closed water just continued to flow into the bilge.
    When I disconnect the hose from the water pump, do I just shove a stopper into the hose? Is there a more graceful way to handle this? Also, isn't it a huge risk to have a water inlet that I can't shut off?
    edited May 12
    Stuff a rag into it or put a plastic bag over it and clamp it and keep the end of the hose above the water level outside of the boat, tie off if necessary.
  • rasburyrasbury Member Posts: 8,962 ✭✭✭✭✭
    But @grouch0jr I understand the worry!
    It should lift above the water line.
    With the rag method, you'll get some water in the bilge, but probably only a few cups.  No big deal.
    This might reduce your stress:  Even if something goes horribly wrong, and the hose ends up sitting there open for a while, your bilge pump can keep up.  It's not gonna sink the boat.
    So use a screwdriver to stuff a rag into the hose, and it'll be fine.
    I did this last summer when we were out on a trip ( usually no worries at home on boat lift), and once the hose was above water level, nothing came in.
    Thanks, I'll be working on this tomorrow.
    edited May 16
    I got the pump changed today, and the water hoses ended up being one of the easiest parts. The original leak was from the shaft. I replaced the impeller housing, but not the back half. Unfortunately it seems like I have a different leak now. There appears to be a slow leak between the faces of the two halves. I put the gasket on and cranked everything down tight, so not sure what the problem is. Is it viable to take the pieces apart and seal the faces with gasket maker?
    Tore it apart again this morning, found my o-ring pinched. Doh!
    edited May 16
    Luckily I had a spare. Everything is put back together. Ran her up to temp then gave her some revs, didn't spill a drop. Thanks everyone for the advice/help.
