Low oil alarm
walkermarwalkermar Member Posts: 57 ✭✭
Hi all, I have had a low oil alarm on my Rinker 280EC 2007. Engine is a Volvo D4 260 with 510 hours. Engine had been running approximately 30mins and at an average speed of 12knots. Stopped to drop a fishing line and then went back into gear, as I did the warning alarm came on. On initial inspection under the hatch, I saw a large volume of oil in the bilge then got a tow home.
pumped out 6ltrs of oil in bilge and restarted the engine to see any obvious leaks but there were none. No marking of oil on the dipstick, but was fine on previous days pre flight check. Oil pressure is showing at 10kpa which I believe is  52ps.
history if that the outdrive was removed in March for bellows replacement and a Small all oil leak was seen on the rubber seal at the top of the gearbox so replaced .
Can they be linked or has anyone had a similar problem before .
many thanks
Mark
  • raybo3raybo3 Administrator Posts: 5,617 admin
    I would assume it's gear lube. Check to see if the gear lube bottle is empty. Might be the hose that goes out the transom.
  • walkermarwalkermar Member Posts: 57 ✭✭
    Thanks Rabo, will check tomorrow but this is about 5ltres. Would that bottle hold that much oil ?
    10 kpa - is that a typo?  52 psi is a good number for oil pressure, but that's 400 kpa.
    With 1.5 gallons of oil in the bilge, is it even possible to leak that much from the gear lube reservoir?  I'm not sure about Volvo.
    Did it smell like regular oil?  Gear lube usually stinks like dead dinosaurs.
    Hi LaRea, I took those readings from the evc and converted to psi but there was definitely pressure there on the display. It definitely smelt like engine oil and not gear lube. As the sump is so close to the bottom of the bilge, it has been suggested there could be a hole in the sump, but I can’t feel anything.
    It’s also been suggested by a friend that the dip stick holder is has a “shark fitting” where it goes into the engine Block which may have come away, hence the leak.
    Just seems like a big volume of oil to be dumped by a leak. The other weird thing is the dipstick is dry, but was checked the day before with perfect readings.
    @walkermar sorry didn't see the 6ltr part. No the drive would not hold that much.
  • Rich_Rich_ Member Posts: 354 ✭✭✭
    If the dipstick is dry, and the bilge is full of oil, first thing is to not run it like that. You will probably have to add oil to the engine until it shows on the dipstick, and then have someone at the key to start and stop the engine while looking for your leak. This will be a messy job to clean. Since you claim to have oil pressure on the gauge but an alarm for low pressure, I’d be looking around the oil pressure switch first, but also suspect oil filter gasket or oil cooler line.
    Hi Rich, the dipstick was at the correct level at the start of the journey and I cleaned out around 6ltres from the bilge post breakdown.. My thinking was that would then leave 6 litres in the engine. I put the oil back in the engine, thinking that would be almost a full amount back in the engine to see what happened when I started her back up.
    on start up, there was no spraying of oil, and no obvious leak, and shut her down after seconds. My plan today is to go back down and see if there is any oil in the bilge and look at the cooler line with a fresh pair of eyes. It was nearly 30 degrees on the pontoon yesterday here in the uk which was a challenge in itself down the bilge.
    I will up date this thread tonight and thank you all so far for you contributions.
    If no blatant leaks, possibly running at higher RPM pressurized the crankcase and blew it out the dipstick?
    If you cleaned 6 liters from the bilge I would assume it would leave 0 in the engine. Maybe it was overfilled and it pressurized and blew out the dip stick?
  • YYZRCYYZRC Member Posts: 5,500 ✭✭✭✭✭
    @raybo3 Volvo D4 diesel holds about 12.5L of oil.
    @walkermar maybe check the oil filter and lines to/from the oil filter.
    Update from today was we started the fine up and witnessed oil coming from beneath the oil filters as you ave suggested @YYZRC . it’s difficult to s the exactly where from but I will try and attach a picture.
    Leak found, end plate of the LO housing below the oil filters . Many thanks for all replies
    Finalmpictures of dismantled faulty housing of the filters….. £2k 🙈 for parts only
    Do you know what caused the damage?
  • aero3113aero3113 Member Posts: 9,964 ✭✭✭✭✭
    Looks like it corroded away in that area.
    Really not sure why it has corroded if I was honest so will try and investigate
  • PickleRickPickleRick Member Posts: 4,388 ✭✭✭✭✭
    Are there any raw water hoses or connection above it where salt water could be leaking down on it?
    edited June 5
    Hi @PickleRick , the intercooler sits above it but nothing too visible so may have been before and just carried on eroding over time
