Replacing pressure valve in water heater
Spyderweb
Posts: 959 ✭✭✭
After 18 years, the pressure valve in water heater started leaking. I finally was able to remove the original and went to Lowes for a replacement. Below is the replacement with the same specs. Only difference (other than it will stick out from heater another inch) is the temp probe is about 1 3/4 shorter. Didn't see any others on the market. This should be OK?
It is a Camco: https://www.amazon.com/dp/B000BQSINO
