U-Line Ice maker
Can I just remove this uline icemaker from the freezer or is it part of the cooling loop?
  • Dream_InnDream_Inn Posts: 7,936 mod
    You can remove the icemaker portion from the freezer.  Sure looks like that one melted.
  • SeaHareSeaHare Posts: 194 ✭✭✭
    Whoa, that one is toast.  Yes you can remove it but the cooling coil under it will remain. You can also replace the ice module with a generic one on amazon. They fit perfectly but will require a small wiring mod to the harness. I just did mine this weekend.
    01 FV 310, 5.7s carbed, B3s
  • tricountytrailtricountytrail Posts: 257 ✭✭
    I'm all set had to jumper a wire on the harness to get the freezer to work.
