2007 Rinker Captiva 262 - Horn Location?
shaffin
Member Posts: 9 ✭
I recently pulled the trigger on a 2007 Rinker Captiva CC 262 and the horn just stopped working. From what I have gathered its the horn that may be replacing, but not sure where is it located and how to get access to it. Any help is much appreciated.
Thanks,
Sam.
Check up by the bow, there should be a chrome plate that looks like a vent.
Different boat but I would think it would have the same type.
Simply take the horn out of the housing and clean the contacts. They look like a set of points if you know what I'm talking about.
Mark
2019 MTX20 Extreme
Thank you all, found it! So just open the 2 screws and take it out of the housing and try to clean and re-test? If that doesn't work whats a good online source to buy a replacement?
Thanks,
Sam.
Not sure if yours is the same, but I can get to the horn through the anchor locker access in the cuddy. That way you dont have to worry about resealing the thru-hull cover. I doubt you'd be able to get the horn out through that hole, anyways.
I was able to remove and replace the horn by removing the 2 screws. It was a quick $70 fix. Thank you all.
Sam.
