2007 Rinker Captiva 262 - Horn Location?
I recently pulled the trigger on a 2007 Rinker Captiva CC 262 and the horn just stopped working. From what I have gathered its the horn that may be replacing, but not sure where is it located and how to get access to it. Any help is much appreciated.
Thanks,
Sam.
    aero3113aero3113 Member Posts: 8,815 ✭✭✭✭✭
    Check up by the bow, there should be a chrome plate that looks like a vent.
    edited July 2014
    Different boat but I would think it would have the same type.
    mvnmvn Member, Moderator Posts: 744 mod
    Simply take the horn out of the housing and clean the contacts.   They look like a set of points if you know what I'm talking about.
    Mark
    2019 MTX20 Extreme
    shaffinshaffin Member Posts: 9
    Thank you all, found it! So just open the 2 screws and take it out of the housing and try to clean and re-test? If that doesn't work whats a good online source to buy a replacement?
    Thanks,
    Sam.
    JoeStangJoeStang Member Posts: 1,116 ✭✭✭✭
    Not sure if yours is the same, but I can get to the horn through the anchor locker access in the cuddy. That way you dont have to worry about resealing the thru-hull cover. I doubt you'd be able to get the horn out through that hole, anyways.
    2013 276 Cuddy ~ 350 MAG / B3
    I was able to remove and replace the horn by removing the 2 screws. It was a quick $70 fix. Thank you all.
    Sam.
