260 questions
MIKES342
Posts: 182 ✭✭✭
1. how do you remove the pedastal for the table in the cabin?
2. how do you lower the pedistal and make a v berth?
3. There is a black plastic cap that screws on and off around the gas filler tank. What is it for?
4. The cockpit wash down is it supposed to pulsate. Is it fresh water or lake water?
Thanks for your response. 3. is a vent for the fuel tank on the 2013 my dealer called today. 4. the pulsating I was talking about is the option of a cockpit wash down with hose, It comes from the water outside the boat.1. Your response helped me figure out how to lower the table.
Thanks again
There wouldn't be a cap on it. If it has two small recessed holes to accept a black plastic key I'm pretty sure it is the water. I have the Sam boat just last year's version. Can you post a picture?
I think so. Thats what they said anyhow. The water is labeled water. This is a black plug about 1 " in diameter.Once you scew the plug out there is a male connector below it. I am going to crawl zround in the engine compartment to see where it goes I'll let you know. Yes I will try to post a picture later this week
will take a picture this weekend
not the fresh water fill. It is a little forward and says water this says nothing.
I believe it sis some kind of vent. but for what I don't know. If I remove the cap there is a threaded male connection in sinde of it. I am wondering if it was a vent for gas so a person could connect a hose with a bottle attached to prevent fuel from going overboard. I will take a picture of it tomorrow
