Bravo 111
Anybody know the weight of a bravo 111 sterndrive?
    Just the outdrive part?
    You can google Bravo lll dtrive weight or go on the Mercury Marine website for accurate weight. MT
    Yes just the outdrive
    MT,
    I did google but could not find the info
    Paul, my 2014 Bravo 3 "X" drive is 148 pounds. I have read that some of the earlier B3 drives were in the 128-130 pound range. MT
    That seems heavy for just the outdrive? I can carry my B3 myself. I would have guessed ~100#.  Either that or the spinich helps!  lol
    Dream_InnDream_Inn Member, Moderator Posts: 7,562 mod
    BD, that spinach must be some good stuff! (just ask Raybo :smile: ) I'd be really impressed if you could lift the drive and put it back on yourself as well! (heck, I'd be hiring you when I need service - I'd even hold the raft steady behind the boat on the lift :smile: )
    raybo3raybo3 Administrator Posts: 5,460 admin
    I strong to the finish cause I eat me spinach...........lol I hate spinach.....
    pepmysterpepmyster Member Posts: 308 ✭✭✭
    Love the references :D
    Here it is boys (and girls) direct from the horse's mouth, so to say:
    http://www.mercurymarine.com.au/home/mercruiser/sterndrives/drives/bravo-three.aspx
    edited August 2014
    What did that MT guy say? 148 pounds?  ....some of the B3 earlier drives, for whatever reason, weighed 8 to 10 pounds less. Maybe they weighjed them without ss pins or something - who knows. But around 148 pounds for an X drive gives you a decent idea .....as I said. :-) .....and I sure would appreciate being referred to as "the horse's mouth" as the Admiral has been known to refer to me as the other end of that animal. :-) MT
    MT - 10 lbs less, with or without the props?
    WO props I do believe Mark, but willing to be corrected. Last Fall I had several conversations with Mercury technicians to TRY to determine the weight of my soon to arrive 8.2 engines and X drives. I was trying to calculate how low in the water the stern of my 2014 EC 360 would sit so that we could draw the line on the hull for the bottom coat. An acquaintence of mine had a Rinker 350 with 6.2s (377s) in it and I was trying to figure how much lower in the water my 8.2 B lll "X"s would sit. I got numbers that were all over the place, but in the end I calculated about 148 pounds for each 2014 B lll "X" drive. As Paul found out, you have to dig for the info. One site gave the weight as 150 pounds - then the article went on to mention that was the SHIPPED weight in a box! Not easy sometimes, eh? :-) MT
    I should clarify my comment above, that was carrying the drive less the props. :)
