Doing a good deed cost me
mheitman23
Member Posts: 25 ✭✭
Went on a weekend trip and on our way came across a stranded boater who needed a tow..as we were towing into the marina came across some shallow water..it didnt sound or feel like it hit too hard but when I took the boat out of the water today it did take a couple nicks out of my ss prop. I put the muffs on when i got home to see if anything was bent and there was a very very slight wobble you could see on the hub of the prop..should this be a concern or need fixed? I didn't notice any vibration the rest of the weekend
Post edited by mvn on
The good news is that ss props are real tough the bad news is that they are real tough. If you hit something hard (rock) with an alum prop it is sacrificed (cheap). If you hit something hard (rock) with an ss prop, with enough force to nick it, there is a possibility that the prop shaft could also get bent. I recommend that you have the run out of your prop shaft checked. Any decent tech has the tools and the knowledge to do it. Take it somewhere you trust. IF and I say IF your propshaft is bent it will be FAR cheaper to have it replaced now that when it shakes the sh*t out of your drive. Fingers crossed. MT
Thanks for the responses. Good news brought it to my mechanic and said im seeing things and that nothing is bent...just going to need to repair the prop this winter
Good outcome! MT
I agree, good outcome! Banging up SS props normally wrecks other things.
Like they say, no good deed goes unpunished!
But I get the feeling that you'd do the same all over again if called upon....as we all should.
Mark
2019 MTX20 Extreme
What happens if the rope gets tangled in your prop, now you have two disabled boats. What about if a storm kicks up and starts to kick your a$$ while towing?
I dunno, I'm all for helping people in need but it seems like around here the people needing help are the least prepared and often dangerously so. Took your 30 y/o 20' bowrider out on the lake and ran out of gas? No map, compass, VHF, or tow coverage? There's a point when bad luck is actually bad planning.
BTW what does **** mean?
Tony, There's little doubt that the little lost girl was attracted to your awesomeness...and that sweet 342.
Mike
Do you feel for the guy that gets stuck in the snow with his RWD sports car with summer tires on? You towing him home?
If people just go out thinking someone will always help them, isnt that possibly perpetuating the problem of people being ill-prepared?
I dont know what its like where you guys boat, but we get TONS of trailer boats that get dropped in the lake and then have issues. Many of them are small inland boaters that think St Clair is just another small lake. Its really amazing to me to see the lack of respect for the water.
Sounds like you called it right. Mike
