Festiva 212 (Yr 2000) anchoring
Hi, does anyone else notice that the position of the bow navigation light directly below the bow anchor cleat on the Festiva 212, means that the nav light could be caught by the rope under strain and possibly be damaged/chaffed, certainly looking at other boats in my marina with similar configurations, more than 50% are missing their nav light covers.  I have tried to work out how to prevent this and have come to two solutions:
1) use the bow eye (winch point) to anchor off using a clip and an attached rope so that I can pull the anchor rope up rather than having to lean out over the bow.
2) install some chocks on either side of the anchor cleat or one fairlead at the front of the bow and feed the anchor rope through those
Ideally I would like to fit a a single bow rope guide, or chocks but have no experience of fitting these, have any other owners installed chocks or fairleads or have any other suggestions, thanks
    Prusik Knot. Info on this forum. Use it all the time - VERY effective. Good for the boat, the bow roller, boat control and safety. easy to learn. MT
    My old 232cc had the same issue while anchoring. What I used to do was throw the anchor, then cleat the line off over the bow rail. Not the best thing to do if you are in an area that gets waked a lot, but it worked. It kept the anchor line from hitting the light.
  • JamesNorman368JamesNorman368 Member Posts: 2 ✭
    Thanks for the answers , I am going to try the prusik knot, thanks
