ignition selonoid
rasbury
Member Posts: 8,270 ✭✭✭✭✭
I was trying to find a thread that was already started, but, someone was having issue with turning the key and getting nothing...and keep at it and it starts which I am having also. They mention and several chimmed in that there is some sore of selonoid (not at the starter but on top of the motor) which I see in the manual but can't really determine where it's at....is the starter at the back of the motor like a car? If the starter has a selonid on it which looks like it does from the manual, what is this other one for??
mike
you can jump the solenoid too next time it acts up, it will let you know if that is the problem.
10-4, may or may not be our problem as it has not failed completely. I did notice while looking this over there was another "device" right with it, does not appear to be part of the ignition looking at the shop manual but looked like some corrosion going on with the wires...was going to post a picture but once again the rain shot me down but will keep looking at that and getting more familiar with the motor layout- sure a lot more to this than the 3.OL in my last boat. I can't even reach and find the starter, would you have to yank the motor to change it?
If your starter is.dead it would likely make funky sounds when it charges, primarily the throw out lever...
The explanation you gave is typical of a solenoid dying, as it works most the time, then some of the time, then not at all when they're in their death throws. and remember, the solenoids, especially the slave solenoid, are there to protect your starter and are sacrificial... Most likely it is that solenoid.
Changing your starter is the last thing you want to try with the engine in the boat. Just change the slave solenoid......... oh yeah. Change the slave solenoid, it's failing.
Just sayin'
Hope your enjoying your boat. It sounds like your learning the proverbial ropes.
Mike
I have a shop full of wrenches but only one that was the perfect length and angle to get a serious bite on that cursed nut. Get it tight and your slow/hard start MIGHT go away. I do not recommend trying to take them completely off to visually inspect them unless you're committed to some serious anger management.
Pull and clean all your battery terminals and slave solenoid connectors too(even if they look good). If it's still an issue even after putting in a new solenoid then you may have a battery cable failing internally. That usually happens near an end connector but can happen anywhere there had been a nick or mfg defect in the insulation.
Good luck.
Mike
ok, two questions as now the boat barley sounds like it wants to start like dead batteries. Please resist that comment. So, we have been talking about testing the starter slave selonoid. I have a set of jumper wires, one side with big clamps and the other side probes like a meter tester, made it for something...anyway, I pulled to wires off their posts and you have the two posts that line up front to back to the boat and then the larger terminals on the top. Does it matter which to jump? I tried it and it clicked and clacked like it was connecting, but did not seem to be able to power the starter either. So, Can I one either of these posts/ terminals use my jumper caples and say bi pass the cylinder so I am sending power to the side of the slave cylinder that would power the starter selonoid and assume the larger posts and for sure know it is the slave cylinder bad??
Next one is tuff. This has been an issue since purchases, just worse. I replaced the batteries by swapping out the same as what was in there. I am starting to wonder,and don't know much about batteries, what CCA etc. should be in there for the 2005 MPI 350 motor? I know I will get a variety of opinions but would like to know what mercruiser would set the boat up with when sold new.
girls, only way to know is get familiar with a volt meter...I'm trying as well.
Now then, here is how I tested mine per the manual. I removed the small post pull offs and marked them and then the larger posts and marked them. Had two jumper wires from the battery, positive was on the near post to me and ground the rear, set the voltmeter to continuity and tested. I can here it click but it did not read anything on the meter. So I pulled it off and tested it again and now seem to get a reading. I like the meters that make an sound instead of a gage. Anyway, I will test it again as it's hard to have four wires going on and know everything is connected so I know the test is accurate.
Also, looking at my battery I was surprised to what I found. I have attached a copy of the label and it appears it was not a large enough MCA as I thought- I replaced what was in the boat. With this lower amp battery, it did start but weak, would it eventually killed the battery by over drawing the battery for the last 8 months or so? Some the battery sites I looked at showed with CCA ratings what normally is a comparable MCA battery, the MCA on this battery was lower. Electrical stuff drives me nuts and I know that is a bad problem to have and own a boat!
