Tell me about this dinghy
JoeStang
Member Posts: 1,116 ✭✭✭✭
So I just bought this today and got a really good deal I think.
Its a bit dirty and some stains, but I think it'll come out nicely with some scrubbing. Its a Quicksilver 330 with a high pressure floor and inflatable keel. Its 11' long.
I plan on using it as a tender to take my dogs to shore to use the bathroom and maybe cruise the canals for some fishing & exploring.
Couple questions:
1. How do I know that its 100% inflated? Is there some type of gauge that could go inline with the electric pump I have?
2. I figured out that the spring loaded stem can be twisted to lock in the "open" position, but how do I not lose any air when pulling off the pump? Is there a specific fitting for this type of valve that pushes down on the stem when inflated instead of having to twist it?
3. Its rated for 15hp, but that seems a little over kill for me. How do you think it'd do with 5 or maybe 9.9hp? I'd like it to plane so its not pointed bow high like crazy but dont want to drop a grand on an engine.
Thanks, any pointers are appreciated.
Couple questions:
2013 276 Cuddy ~ 350 MAG / B3
The push/twist to lock if for deflating, the air from the pump will push past the valve, so you want it locked/closed to inflate. You can get airpumps with pressure gages or at least just the gauge itself that fits to the air inlet. Put a call into Wolf's Marine in Benton Harbor, they are like the dinghy kings and they can help with the pump/gage or at least offer help.
Just so you don't over expect, the airdeck floor types are not the best for planing, and who/what you have in it makes a major difference. I'm sure it can handle 15hp, but what are you doing with it? A run from the boat to the beach with kids and eats? How are you transporting the dinghy? Taking off a heavy motor in bobbing seas is a royal PITA and an eventual drop in the water. An older 2 stroke 9.9 is 68#, that 15 hp 2-stroke will be closer to 100#, a 4 stroke 9.9 is 95#..so you see the deal with the weight. Needing to plane means bigger HP. I had a 3.3hp 2 stroke on my 8'-6" airdeck, works fine for just putting about and to the beach, even had it out in 6' waves one day (another story). My new AB 9.5AL has the 2 stroke 9.9 and it flies...but it is a RIB too.
A decent used 9.9 2-stroke will set you back ~$750.
Best of luck!
It'll be mostly for transporting my two dogs to & from the boat to shore for restroom use. They refuse to go on the swim platform even though I know their bladder is bursting. I wouldnt even really care if they went in the cockpit with the carpet up, since its self-bailing and I can rinse it down the drains easily. Otherwise I might cruise the rivers and canals up here to do some fishing and cheap cruising.
I plan on storing it upside down on the cuddy deck, and if it isnt TOO huge I might try to keep it up there when cruising to an anchorage. Otherwise I'll have to tow it behind or pull it halfway up the swim platform and tie it down to the rear cleats. I'll take the motor off regardless of how its stored when cruising.
The more I think about it a 9 or 15hp 4 stroke would be really nice when taking the dinghy out for a cruise from the marina, but for going to shore when anchored out I could just row it. It'd save a lot of setup and a little exercise wouldnt hurt. LOL
I gotta clean it up, but here's some quick pics today.
Here is the air pump I mentioned
http://www.solutiononemaritime.com/inflatable-boat-accessories/319-zodiac-z7111-pressure-gauge.html
if you do get a 4-stroke, pay attention to what side needs to stay 'up' when on its side or you'll hydrolock it with the engine oil too..not good.
I just dislike how smelly and noisy most of the 2 strokes I see/hear around me. Are the newest ones any better? Not many of them out there brand new from my quick searching. I definitely cant drop a ton on the engine, but I dont want to waste time and money on a 30 year old relic because its cheap.
I found this dink on CL and likely will find the OB there too. I'll bet someone needs some christmas money in a couple months.....
Used LA's Totally Awesome with a scrub brush and my 2200psi pressure washer for the really tough spots. It came out almost 100% perfect, with just those strange really dark brown spots not budging at all. Its held pressure for almost a week now with no leaks, so I'm guessing its all good to go.
But yeah, its in great shape now and ready for some putzing.
