Does the engine water pump require any service?
350 mercruiser, going through the manual for the regular service stuff and it has the info for changing the filters, pvc valve, all the easy stuff. I have a bravo II out drive on my Tahoe that has the water impeller in the foot and from what I've read not the case on the bravo III in the Rinker and there is not an impeller in the foot but a water pump I assume similar to a car on the motor.....and being like a car pump not really any service to be done or is there an impeller in that pump that should be replaced? And the coolant, should that also be replaced on some sort of schedule? I did not see anything about that in the operation manual...I don't have the service manual but there is some details of service schedules in the operation manual. It is a closed cooling system with heat exchanger
Best Answers
TikiHut2 Member Posts: 1,431 ✭✭✭✭✭
Find, download, and study the merc service manual posted in the RBOC archives. There's a wealth of info in the archives alone.
My '04 merc 350 isn't a closed cooling system so I'm not much help there. I'm nearly positive that you'll still have a raw water pump somewhere near the frt starboard side of the engine, and a separate engine circulating pump (like a typical car engine) on the frt of the motor. The raw water pump will have a rubber impeller that needs to be replaced every other year with avg use. The other one should be replaced if it ever dribbles water from the shaft (indicating a bad bearing) or if your temps are suspiciously high for no other reason. Other will chime in with more I'm sure.
There was a lengthy thread with pics on my little impeller replacement drama due to a merc mfg defect that might be a good heads up so you don't have to live through my experience. Here's the ((LINK)). The moral of the story....take your old impeller with you to the parts dealer and DON'T install it even if it's a tiny fraction of an inch off in size.
Good luck, Mike
2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl -
Dream_Inn Member, Moderator Posts: 7,728 mod
Yes, there is still an impeller that pumps raw water thru your risors & manifolds. It is more than likely in a pump on the bottom left side of the motor (under alternator). Typically there are two hoses that come in on the back of it and two bolts on the engine as well as a bracket that may go to the alternator for removal. There are like 6 bolts on the pump that need removed to get to the impeller. Also read the post that Tiki posted.Dream 'Inn III -- 2008 400 Express
Yes, B3s only have the pump on the engine. Ras, I still learn something each time I'm on here.Dream 'Inn III -- 2008 400 Express
MarkB Member Posts: 3,991 ✭✭✭✭✭
I believe the raw water impeller should be changed every 3 years.Boat Name: King Kong
Ras, a little trick when installing the new impellor, use a larger wire tie to help compress the impeller into shape as you push the new one back in. It should slide off as you get it in.Dream 'Inn III -- 2008 400 Express
youstolemybeer Member Posts: 246 ✭✭✭
had the same happen to me, only I was drifting downstream when the belt broke and took out the fuel pump that lives on my water pump housing. If the pump doesn't spin than either you have a chunk of the impellor jammed in the housing, OR the bearings in the pump are shot. both are not that bad to repair. -
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
Ras: if the belt is the correct length and type, the 'marine' and auto belt are exactly the same...except the price of course.
If the raw water pump will not turn you almost certainly have a frozen bearing and that will take out a belt pronto. There is no sense in wasting your time or money trying to rebuild it, others will testify to this too, go new and this would be the ticket:
http://www.hardin-marine.com/p-15774-stainless-steel-gen-7-sea-pump-for-mercury-350-496-and-502-mag.aspx
PC BYC, Holland, MI -
Glassguy54 Member Posts: 588 ✭✭✭
Our Bravo III pump went out early this season, in fact, the first time we tried to go out! Got the high temp warning alarm and the gauge indicated over 180, so got it back on the trailer and took it to the marine mechanic. They at first tried to just replace the impellor and that didn't cure the problem, so they wound up having to replace the entire pump assembly, which on the 350 MAG MPI Bravo III is rather tough to get access to. Tiki claims he can do it in about a half hour, which I find incredible, but I paid to have ours replaced and it cost about a thousand bucks - parts & labor. Not exactly how I wanted to start the season. -
NOTHING like the starter. Thank God for that slave solenoid up on the engine eh?
Spray any bolts with penetrating oil the day before you start and you'll thank me later. Hope yours is a straightforward fix but at least it didn't require TowBoatUS or an angry admiral/crew....... or a busted block/engine head
My Kohler genset impeller coupling broke doing a flush on the trailer at my shop last week. I had been planning on staying on the hook numerous nights on the prior trip out but because of the oppressive heat we slipped into the Hyatt marina. It certainly would've failed on a blistering hot/humid night if we had counted on it. Lucky break for us.
Good luck. That raw water pump is really pretty easy once you do it 5 times in a row like I had to.Hope that's not the case for you. Mike
Ras, I've been there done that, on a couple 270s. Those little air hoses, you can squeeze them and then they will come off. Took me a couple times before I learned that one. BTW, you can use the little pump thingy and it will allow you to pump out the salt water when you are done for the day (or for us northerners, we use it to pump out water for winter). Note if you do that, there is a little relief valve to pull when done pumping as well.
As far as the pump/impeller, you are better off removing the back two hoses and taking the entire pump off. You only need to remove the bracket that goes up to the alternator, not the alternator. The hoses are a bit of a pain (note that one hose is larger than the other), but lube them before putting back on and they will go right on and off next time. If you have a red hose coming off the pump, you can use go follow it towards aft and use a little metal clip and take that 3 ft section hose with the pump (I think your boat may be too old, but not sure...started doing that around 2005 I think). Also, you can use a wire tie around the new impeller when installing to help.Dream 'Inn III -- 2008 400 Express
Cableguy Greg Member Posts: 5,047 ✭✭✭✭✭
Closed cooled, it would be coolant. Sea water cooled, rusty water.
Just got caught up on the latest story line. I feel your pain. For me it was the funky impellers with the mfg defects helping me gain a more intimate understanding of the twisted shoulder/stabbing sharp pokey thangs everywhere. In/out 4 or 5 times for ONE replacement that worked. The upside is that I got REALLY fast at it. NOT a skill-set I really needed. Think Karate Kid...... Mr Miogi, Wax-on, wax-off. repeat until you accept the drill for some unknown skill you'll need in the future.
Definitely easiest to completely remove the whole pump at all costs.....except don't cut any hoses no matter how frustrated you get. Get those batteries outta the way too. Hey, hang in there and no short cuts.
Mike
I had posted pics and details/tips on replacing the raw water pump last year on our '04 5.7 merc. (links above in my post last year) I pulled mine 3 or 4 times before it went right due to a rash of impeller recall issues. Be aware of the fractionally small change in size of the old/defective impellers /vs/new. A 1/16" makes all the difference between frustration and success.
A new complete pump assembly is upwards of $450. If the bearings ok and money's tight you can get a new impeller, but also get a stainless backing plate kit sold on ebay if the housing is scored even slightly. Take a picture of the belt routing as mine was NOT installed like the handy decal on the thermostat housing.
Good luck. Mike
As far as the pump, there should be a shrader valve on the top right side of the engine (near the gear lube reservoir) and next to it is a valve with a key-ring loop on it. You use the little blue pump (mounted on front of engine - unless it fell off, real easy to do) to connect to shrader valve and pump. When done, just pull the little release pin to help release pressure and the valve at the bottom of the water distribution will close. It is that simple.
The little handwater pump should remove water from the heat exchanger as well. It just works under pressure thru the system. It pumps out in the bottom front right corner of the engine. I'm trying to remember exactly (I just did it this past Saturday), but it's near the multi-drain area.
Ras, don't give up on those hoses. I've had some just as bad, but I've used leverage of the engine and rotate it up as I pulled. Once you get them off, the next time around is a very simple. Some reason the first time, those hoses just mend themselves to the fittings. Make sure you lubricate the inside of the hoses before putting back on.
