B3 lower....toast
SeaHare
Member Posts: 194 ✭✭✭
So on my way to the trailer (by boat) to pull out for the season, i was running up on plane and all seemed well. When I came off plane and stopped to wait for a bridge to go up, I notice when i put the port drive in gear there was some awful grinding. When I got the boat on the trailer i turned the props by hand and sure enough, crunch, crunch, crunch... I also noticed the gear lube monitor was overflowing, so i opened the cap and POOF!, pressurized gear lube blew everywhere.... looks like its time for a new lower, hopefully not a whole new drive. Not the best way to end the season but if it had to happen, i guess now is the best time
01 FV 310, 5.7s carbed, B3s
I can recommend:
http://www.allamericandriveservice.com
at least call them. They can advise about the upper part. They offer a 2 year warranty too.
Best of luck!
beware, though, witches are tricky it's been my experience... one actually talked me into marrying her once... that didn't end well, but, alas, it ended...
sorry to hear this, Sir Sea Hare, but through humor all things are better.
Good luck and keep us updated with your decision.
x
1. there does not appear to be any water in the drive
2. the gear is black as the ace of spades and smells burt
3. the little magnet on the lower plug is broke off so i dont have much info if there are metal shavings in the case.
4. I can pull/push the rear prop about 1/2 inch
My mechanic said once things slow down this winter he will be rebuilding a bunch of drives and he can rebuild mine for a good price "if its not too far gone".
Im hoping to keep this repair under 2k, I hope thats not reaching for the stars
