GALLEY FRIDGE IN A 2006 342 fiesta vee
Has anyone replaced their galley fridge ? .in looking at the door  opening does it go through with no hassle   tks
    CraigyCraigy Member Posts: 1
    Did you ever get anywhere with this? I have a 2003 342 – and have removed the fridge (Tundra) but it doesn't seem like it will fit through the sliding door! Awesome design!
    raybo3raybo3 Administrator Posts: 5,460 admin
    Hey a couple of my friends have the same problem. Can not fit the fridge through the sliding doors. One is a SeaRay and other is a Hydro Sport.... I assume its a common problem to boating.
    If you can't get the old fridge out, how will you get a new fridge (of the same size) in?
    RY, I meant if taking the door off doesn't work.
    I was just curious since mine is not working the very best.  Mine sweats on the inside.  Planning to have a friend who does HVAC try to charge it.
    I've noticed mine sweating more on the inside as well lately.  Not sure why, but it's coming just from the freezer area.  Seems to keep things cold and freezer stays frozen, but it is something I've been monitoring.  If you figure something out, please let us know.
    I agree with RY
    I'm pretty sure someone on here was talking about replacing their fridge like 1 or 2 years ago, and they had to take the door off. I'm pretty sure if you do that it will work.
    SERENDIPITYSERENDIPITY Member Posts: 83 ✭✭
    WELL in short the  freezer would  freeze all except by the  sensor on the back  so the sensor area being thawed would always be running .  my fridge man said it cannot be fixed .so all i did what get a frozen pliable  water  bottle  place it on the sensor  and voila  freezer /fridge/tundra   runs and shutoff normally
