WATER!!
So my 300 was leaking oil from the starboard engine. It turned out to be the front seal on the timing chain cover. They were able to change it without removing the engine, Thank God.
Since the repair WATER!! has been in my bilge, about 5" under the engines every day. I brought the boat back to the marina and the say its leaking in on the port side rear up under the water heater and water tank where the trim tab mounts to the boat. I swam under and all the screws were tight and every thing felt normal. I also checked the swim platform support arm and that seamed normal too. They say its not the through hull fittings. Any ideas? Im baffled.
Thru hulls, leaking a/c raw water, toilet raw water, out drive bellows, gimble pin...or you got hull damage somewhere.
It's not too far from what those bilge pumps are being asked to do with all that water EVERY day. Bilge pumps are designed for a duty cycle that is far less than that kind of DAILY volume. My guess is a bellows leak. It should be fine unless the bilge pump has ANY type of glitch....... My .02c, pull the boat. That's serious volume.
Good luck, Mike
