Have serviced - fixed, And sill to go
Trying or have done myself to save money
--- Replaced or fixed ---
Hot water heater --- new
Fuel filters --- new
Inline fuel filters --- new
A/C water pump --- new
Windless --- being fixed
Shower pump --- new
Fresh water flow --- fixed
Toilet pump --- on order new
--- Still to go---
Manifolds and risers elbows --- there about 5-6 years old
Engines impellers --- no clue how old they are
Generator impellers --- no clue
Thermostats --- no clue
Most of the console gauges --- sometime they work mostly not
O and the out drives --- three years since last serviced
Is there something else I need to think about doing, I'm not looking for more stuff to do its already a small fortune
I'd rather be safe and know when things were done, put on a regular schedule.
I guess this is the part of buying a used boat
Generator impeller on the 5e: annual - also note the in an anode in the heat exchanger to be serviced and the is a coupling that connects the water pump to the gen set that should be watched / replaced too ($15).
The gages are known (especially the tachs) to be not all that good. Search around on here as several of us have done things to replace them with upgraded gages.
