coffee maker removal
how does one remove the coffee maker from a 2002 342 Fiesta Vee, besides using a hammer and sawzall????
    I have notes on this and will post later!
    Good luck.  When the dealership did it on my 2003, it took two guys an entire day.  Had to take apart the entire galley.  BUT there are a lot of differences from '02 to '03.
    Its a real PITA to do. If I am not mistaken you have to remove the microwave oven. Is your not working or you just looking for more storage????/
    golfdoggolfdog Member Posts: 151 ✭✭✭
    I removed mine a while back and don't remember the exact process. It wasn't as bad as I thought it would be. I have a 2003 so I'm not sure if there is a big difference between th years. I remember I had to take screws out in the shelf area above the coffee maker, I also remember the need to loosen the microwave. I think it kind of became clear as I went. Take a few screws out, check what loosened, look for more screws, etc.....
    Dream_InnDream_Inn Member, Moderator Posts: 7,564 mod
    If it is similar to my old 310, I removed microwave and removed screws in shelf area above coffee maker (as golfdog mentioned).  Really wasn't that bad.
    I had to take the cabinets apart to replace my micro wave. I noticed 2 screws that held the coffee maker in place. So if I wanted to remove the coffee maker I would have to remove the micro witch means I would have to take cabinets apart. Again a real PITA.........
