Water system winterization question
Cableguy Greg
Member Posts: 5,014 ✭✭✭✭✭
This is my first year with a cruiser, and I have winterized my boat. I went thru the water system by dumping pink in the fresh water tank and ran pink thru all of the lines. The question is, I have used the city water connection all summer while at the dock. There is about 8 feet of water line that I can see from the connection to the rest of the system. I did not run pink thru that section of the system. Should I connect an external bilge pump in a bucket and run pink thru it, or will it be fine. I have heard that it will be fine, but I don't want to find out the hard way in the spring that I should have ran pink thru it.
