Loud ticking noise
mvn
Member, Moderator Posts: 763 mod
2008 5.0L Mercruiser coupled to an Alpha One drive. Towards the end of the last boating season, I detected a loud ticking noise coming from right cylinder bank. Increased ticking rate with RPM. Also detected an abnormal odor in the engine compartment. Felt hot gas pulsations coming from the vicinity of the #1 spark plug. A mirror placed under the exhaust manifold showed a protruding manifold gasket. I removed the exhaust manifold and checked the exhaust shutter. Then I looked at the gasket (see attached). This engine was never worked on... factory original. Turns out there's a service bulletin out there claiming improper exhaust manifold bolt torques from the factory. After replacing the gasket, all is well again.
Mark
Good, fast, cheap.... pick two.
2019 MTX20 Extreme
2019 MTX20 Extreme
Well, on a 226 the starboard side is easy. The port side, that's a different story especially when you're trying to do it yourself!! I figured out a way to rig a beam across the engine compartment opening and support the manifold with ratchet straps. Worked out quite well.
Mark
2019 MTX20 Extreme
Alswagg can comment better than I; however, reading on other forums shows that it is primarily a GM small block issue on all years. Some have used Volvo or Fel-Pro gaskets with better success than Merc. Failures seem to readily occur between 20 and 60 hours.
Mark
2019 MTX20 Extreme
The mighty "Remflex" gasket is the answer.. it will seal even warped manifolds.. they are pricey, but worth every bit of the cost.. if you couple the remflex gaskets with stage eight (not grade eight, but stage eight) bolts, that problem is forever solved..
Here's a link to Stage 8 Fasteners. Very interesting..........
http://www.stage8.com/
Mark
2019 MTX20 Extreme
I've also used these, which I don't recommend.. :
