Not sure what this is on a 342 Fiesta Vee??
CaptianDan
Member Posts: 94 ✭✭
2
I have taken delivery of my long awaited Rinker 342 today and wondered if anyone knew what this is? I'm guessing it's an intake for the outdrives separate from the outdrive but want to make sure. Is these anything I need to check on it before it goes in the water?
Appreciate any help!! :-)
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
Tony
Salt Shaker 342
"Pipe Dream"
"Pipe Dream"
"Pipe Dream"
While I'm asking noobie questions I was wondering what the three outlets were on the stern below.
"Pipe Dream"
Tony
Salt Shaker 342
"Pipe Dream"
Dan, they are probably exactly what Tony said. I'd guess two are for flushing each engine. Follow the lines inside and see where they go. I'd be curious if there is a "T" or a one way valve, or if it is counting on those plastic caps to keep from drawing air in. Definitely something you should follow up on.
Thanks
randy
Tony
Follow-up.... I found out what the inlets were on the stern after tracing back, etc. The bottom one is indeed the shore water hook-up and the top two are port and starboard fresh water flush for the engines.
"Pipe Dream"
