Drive trimmed fully up, won't trim down
robc
Member Posts: 10 ✭
I used the trailer switch to bring drive all the way up. Tried to lower it and it wouldn't go. I loosen up the hydro line and drifted down a little then It worked fine. Any thoughts.
If it needs oil then it'd show up somewhere in the bilge as a greasy mess. If a down trim solenoid is bad it'd just be silent when you press the down switch.
Good luck, Mike
oops, just realized this was a 6wk old thread. oh well. Have a great season everybody....Cmas season that is. Boating season is right around the corner
Cleaning the trim pump oil tank is a normal maintenance item that's often neglected too. Before you spring for a new pump try removing and cleaning the tank and refresh the fluid. Also check all of the solenoid connections for a corroded (low voltage) connection. My money is riding on a simple fix but good luck.
Let us know how it goes.
just sayin.
I've had a sticky ram after a launch due to a tight anode and simply reach under the swim platform using a dock pole to add 10-20lbs of downward pressure. Once fully down and underway it's freed up and won't complain again......until it sets for a few weeks/month waiting for the next trip. A pretty common but simple fix.
