What size batteries should I have on a 2004 Rinker 282 bowrider?
Best Answer
OptionsNice and Naughty Member Posts: 31 ✭✭
FamilyTruckster - I have a 2005 282BR and use 3 Costco Starting / Deep Cycle Batteries. 2 of them are wired in parallel (#2) for when on the hook and running the stereo system with 4 amps + Refrigerator. I am assuming that you have the 496 Mag or HO? I was told that these engines require a lot of power to start and that the battery switch should be set to both instead of #1 or #2. While underway I leave the battery switch in the both position to continue charging the batteries and then switch over to #2 when we stop. We usually make a 20-30 mile run so the batteries have a little time to charge. I always have #1 available for starting if #2 has used to much juice during the day. I've never had any problem with these batteries and they keep the tunes and fridge running all day long!
Not sure exactly what happened. Repair shop spent time and realized that the fuel pump wasn't getting power. Not sure what they did, but they got it to start again and ran it for over an hour. They recommended to run it on both (I never did b/c salesman said that we should always run on #2 then cove out on #1 then switch back to #2 for the start/drive) from now on to ensure both batteries are receiving equal charge.
Their theory about the fuel pump was that the battery that it was wired to was opposite the battery I was running on and eventually it was not receiving the charge and got low enough for the fuel pump to stop. I wonder about this since I put about 8 hours on the boat over the weekend prior to this and had no problems. Of course, I ran the stereo this whole trip so perhaps it did wear it down. I don't know. They also said that I need 1000 cranking amp starting batteries for both batteries. Currently have 650 and 700 (starting / deep cycle). I don't remember changing batteries last year but the wife tells me I did...
I have never had a two battery boat before so this is all new to me. One more question - when I plug in shore power is that charging both batteries?
Thanks guys,
Family Truckster
