2006 270 fv. Fresh water leaking.
terrypage
Member Posts: 165 ✭✭
The boat is currently laid ashore and while we were polishing today, suddenly water gushed out from the mid bilge outlet starboard side. Despite checking all the taps shower etc. no leaks were found. I cannot find where the mid bilge pump is hiding. The water is coming from the water tank, the electric pump struggles to stop running when the switch is turned on. My question is where is the inspection hatch, the carpet appears to be glued! Has anyone had this problem?
http://rinkerboats.vanillaforums.com/discussion/comment/8945/#Comment_8945
Look to this link, looks very similar what I have had in the past.
Well its either a crack or the fitting going to the pump at the bottom
Good luck .
Paul
