Looking for buffing/polishing advice
All, One of my projects for this year will be to finally try to buff out my boat and get her back to looking nice and shiny. I should have done this years ago, and it would have probably been a lot easier, but there was always something else that had to be done. My boat is all white, no colors to worry about. So being that the boat is looking pretty chalky, I wanted to turn to some others to see what they recommend. Personally, I have been reading about the 3m imperial compound and finishing material. It seems as if this stuff cuts through the chalky finish and can get the boat back to a nice shine with just the use of this one compound, then follow this up with a good 3m wax. If I wanted to I could use a finer polish like 3m finesse it after the first compound if I felt I needed to bring out a better shine, but from what I have been reading, it seems like the imperial compound can really get me where I want to be without using the finesse it. So, opening this up for discussion. What have others done to restore the shine to their boats? Anyone have experience with this imperial compound? if so, opinions? Somebody mentioned wet sanding to me, but it seems to me that I should be able to accomplish this without going to that level, even if I have to do multiple applications of the compound. All opinions are appreciated.
OOPS, almost forgot. What do I do with the non skid areas, like up on the front of the bow, and the swim platform? Do I compound those areas also? I am guessing so, but just want to be sure.
Thanks in advance.
Thanks in advance.
all the necessary Infos are there whatever you nee to wet sand or not.
Hmmm.
SOOO one last time...
Terry had it right. Follow the instructions in this OCD gelcoat restoration link and it'll be as awesome as Terrys boat and the TikiHut. The only exception for me was using a $29 harbor freight buffer.
Good luck, Mike
http://forums.sbo.sailboatowners.com/showthread.php?t=117266
I think the common denominator is elbow grease. I also went with the Harbor Freight orbital.
Paul
http://www.collinite.com/
Awesome finish Terry!!
Cleaning the hull:
Before wet sanding or compounding can begin you should thoroughly clean the hull. For this process you’ll need a cheap rain suit, duck tape, rubber gloves and some ON & OFF, On & OFF Gel or FSR gel (basically acid) and you'll ultimately want a full face respirator rated for acids.. Duck tape where the gloves meet the raincoat so you don't get acid on your skin while reaching over-head, preferably DO NOT reach over head but rather do it from a platform or ladder to wash the boat. I find using On & Off, and a car wash brush, as effective, but far quicker, than applying FSR gel and they are both made of the same basic components (acids). Be careful these ARE acid based products!
Buy a roll or sheet of plastic and rip it with a razor knife into 12-inch wide lengths. Tape this to your dry hull surface at the water line using 3M green film tape (seems to work) at the top but let it hang on the bottom as a “drip edge” skirt. You do this so the acid in the ON & OFF does not eat the copper bottom paint and can drip on the ground vs. the bottom paint. Wash and rinse quickly a small area at a time and do this preferably before you before you bottom paint just in case. On & Off is basically FSR without the gel. However, you can wash much faster with ON & OFF than you can with FSR. The ON & OFF will bring back the white of the hull by removing the metals or tannins. Tannins are that rusty orange discoloration you get from the ocean over time that attach to the gelcoat. You'll be amazed at the difference in the color of your hull! Even hulls that don’t look bad look amazing after a thorough washing with On & Off. This is a very good place to start before waxing if your boat is older than a few years. Be very careful not to get On & Off or FSR on aluminum rub rails, metals, stanchions, cleats etc. because it will pit them. Only apply FSR or On & Off to a gelcoat hull! Allow about 20 minutes for the skirt set up and 1/2 hour for washing the hull.
what is this " on and off"?
