Bravo 3 Steering left and right
I am having issues with my steering on my 2007 230 Atlantic cuddy. I only just purchased it used and it seems to drift left and right constantly. My old boat had no play in the steering at all - 1981 Searay SRV225 alpha one. I am thinking if it might be fixed by using zincs with the rudders on the B III, right now those zincs are flat. Worst case may be gimbal bearing needs replacement but there are only 120 hours on this boat, it sat in dry storage a few years.
loose. Did you notice if you have any water leak coming out at the steering shaft?a know problem on bravo 111 and some alpha gen 11it could be fixed with a kit from JR marine
you would need to investigate where the loose is coming from by moving the sterndrive right to left.
I am going to have it on drydock and then see how much play is around the B3 outdrive. should know in a couple days what my wallet will need.
cheers.
http://www.boatingmag.com/how-to/controlling-low-speed-wander
Well there is play in the wheel and it will not steer straight on it's own at all. it will go left and right constantly. I though it was because of the bravo 3.
will know better when I can push left right on the leg out of water.
Cheers.
Just a thought. Check your prop timing. Scroll down to links from friendship. Maybe someone put the prop on wrong that is adding to prop thrust side to side at low RPMs.
http://rinkerboats.vanillaforums.com/discussion/2204/so-how-bad-is-it
Hi Capt Ron,
Not sure how the props are installed wrong, they are not keyed so can install in any grove. I have the bravo 3 drive. The drive itself does not move left and right when out of water. I wonder if one or two of the blades may have bent slightly?
PDan.
The Bravo 3 twin props can be installed in any position as the hub is splined. However, it is important to have them offset, like in the link Frenchship posted in his previous post, which I posted a link to this discussion. Just something to check.
Thanks again everyone for the prop sinc check. Yes they are at 12 and 6 O'clock.
