Crack in radar arch near base *PICS ADDED*
SeaHare
Member Posts: 194 ✭✭✭
(2001 310)... over the winter, my tarp collapsed and the bow collected ALOT of snow and ice... like up to the bow rail... the tarp must have put a lot of pressure on the arch and it cracked on the SB side near the base where it attaches to the boat.. The gap is probably 1/32" wide and about 2" long... there was small cracking there previously but its worse now
Is there a good way to fix this?
01 FV 310, 5.7s carbed, B3s
Post edited by SeaHare on
The second year I had my '03 342, a fitting on top of the radar arch started leaking water that would accumulate at the base of the arch on both sides. The water froze and cracked the gelcoat because it was pushing out from inside the radar arch. It was not a structural problem, so the dealer repaired the gelcoat by sanding and recoating. They also drilled 1/8" drain holes to keep it from happening again. It worked -- I had the boat another eight years with no further problems.
You said there were small cracks before. That would be consistent with freeze damage.
Do you have drain holes? If not, you might want to consider adding them on both sides.
Also, find out how the water is entering the arch (if that's what happened). Cable penetrations are a common culprit. On most Rinkers, they just pack sealant around the hole where the cable enters the arch. A better long-term solution is to use a cable fitting like this:
http://www.westmarine.com/buy/seafit--coax-cable-deck-fittings--P003_094_003_006
