I used snapincarpet.com for my 2004 312fv.. cost $600 to replace all the deck carpets, only thign is you have to put in the snaps your self, but they set you everything you need to do that. the carpets are cut to OEM templates
I had a local Carpet place do mine and did away with the rubber back dries so much better used Shaw Marine Carpet under $500. did my own snaps it's not the carpet that cost it's the piping around the edges
I also used snapincarpet.com. Very precise carpet cutting if you send in your old set. They also have many patterns already digitized. If you can install the snaps yourself, you will end up with a better installation.
Last year after cleaning my carpet I put it on my boat but did not snap it down because I was running late. A few days later after using my boat I realized I forgot to snap it down. I did not have any problem at all the carpet not being snapped. I guess my point is do you really need to install the snaps????
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
I ordered mine from Rinker a few years back. They didn't have a template for my boat, so I sent mine back and they used it for the template. It turned out well. I did the snaps myself.
2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes" Go Steelers!!!
Mark
2019 MTX20 Extreme
I just got mine from Snapincarpet.com also. I ordered it on a Monday and it was on my porch on Wednesday! Very happy!
