Fuel tank replacement - 2006 FV250 EC
![[Deleted User]](https://w5.vanillicon.com/5b2d60796d1edeb67376e6769d8a5b52_100.png)
I'm looking at replacing my fuel tank due to a leak, probably caused by corrosion. The boat has floated in sea water its whole life, nine years. Yes, worst case scenario, ouch. So the engine is coming out and the 2 month old drive will be coming off. That is the easy part. Any tips on removing the old tank from someone with experience of the job would be much appreciated. I know it involves cutting fiberglass, and I've read about someone who had the same problem on a 270. I'm reading that the tank will slide backwards into the engine bay once there is clearance.
Andy
Andy
The tank is fully drained and the bilge completely clean and dry. Yes, there will be residual fumes in the tank, and it will have to be completely purged or there is a huge explosion risk. This morning the boat was moved from the slip to the ramp using a temporary tank spliced to the fuel line, and that worked like a charm. She was trailered to the yard in Costa Mesa that did my recent outdrive swap for engine/drive removal. The next steps will involve by the far the biggest challenge, the cutting you describe.
When you say "aft cabin" do you mean the "mid berth?" I'm not sure the 270 has the same layout as the 250. As you say, a lot of cutting is needed.
I spoke on the phone with an outfit in San Diego, American Tanks (www.americantanks.com) They make custom fuel tanks in any size and configuration, and are currently doing about 50 boat tank replacements a year. What I learned on that call made me feel a bit better about the situation, but it's still a very bad situation.
I'm unsure if the cause was external corrosion, or internal corrosion to do with ethanol, or a combination of both. It's still a mystery. I'll keep y'all posted.
Andy
Andy
I didn't get a photo of the old tank because it is already at the fabricators being used as a template. I've been told by a couple of different people this tank shop is the best in So. Cal. and I'm going to make sure this is my last tank repair ever.
Andy
Looking at her yesterday it felt like the time we remodeled the house back to the studs and had a huge mess and clear plastic keeping out the weather. The feeling was "gee, I hope all this goes back together OK!"
Since the XDP drive was replaced by the OceanX in January, I've used the boat more than ever, going out three to five times a week taking advantage of our summer-like winter weather. The new drive made her feel like a new and different (better) boat. So I'll overcome this obstacle, learn from it, and move on. One benefit, I know this boat inside and out now, literally!
Andy
Andy
Wow, thanks for sharing this - I have the 250 - built 2002, i need to go through this tank replacement too, however, I am a bit wary since i dont have a clue where to start cutting - i have emailed rinker to ask for a blueprint or some sort of drawing or measurements of where the tank sits so I can cut accordingly - Your images really help, however would you have any measurements?
Thanks in advance
Matt
Andy
Andy
The battery charger will be replaced, it's been flaky for a while. I'm also thinking about putting a small inspection hatch in the bulkhead to make impeller replacement and front engine access a bit easier!
Andy
Andy
Andy
